buchtsucht
| PIC16LF1823 bug in MPLAB or CCS? |
Posted: Thu Aug 26, 2010 9:33 am |
if I write a value to the EEPROM with write_EEPROM(x,y) I can read it by using y=read_EEPROM(x).
But if I write to EEPROM by using #ROM 0xF000={y} the value is not really written to EEPROM - even if MPLAB shows me with VIEW => EEPROM, that the value should be there. #ROM 0x2100 and so on did not work too and datasheet tells me, that 0xF000 should be O.K. Using this function never made problems with older PICs.
Even if I have a account at Microchip, it seems to be impossible to open a account at Microchip - support for me... maybe they have to much traffic???? |
Posted: Thu Aug 26, 2010 10:10 am |
#rom getenv("EEPROM_ADDRESS") = { your data }
Saves you having to work out 'where' the EEPROM is.
0xF000, should be right.
buchtsucht
Posted: Thu Aug 26, 2010 11:31 pm |
| Thanks Ttelmah, that is a good idea, and I will use it in future, but it did not solve the problem. Adding 100pF to VDD should help sometimes, but has no success too. |
Posted: Fri Aug 27, 2010 1:59 am |
If adding 100pF to Vdd, is having any effect at all, it suggests you have a hardware supply problem. You should normally expect to have soemthing much larger (0.1uF typically) immediately adjacent to the PIC.
It is vital to understand, that even if you have a 'perfect' power supply (zero output impedance, and with instantaneous responses to demand changes), connected to your board, once you have a few inches of wire connecting to an IC, you _will_ need local decoupling to keep the supply 'smooth' at the chips, as their demand changes. Wires/tracks, have all sorts of 'nasty' characteristics (inductance, time delay - speed will be well below the velocity of light, etc.), which you _must_ deal with. If you study a high quality board like a typical PC motherboard, you have a very good PSU (normally), being generated to feed the electronics, and thick power tracks, yet there are decoupling capacitors all over the board. Remember that designers of such boards, want to save money, and such capacitors cost money. Theyy are there because they are _needed_...
buchtsucht
Posted: Fri Aug 27, 2010 3:07 am |
Found the solution:
In PIckit3 settings / Memory / manual select Memory ranges / EEPROM was not activated. Maybe this happens while changing the device. |
