Datalogger with 18f4553 and sd/mmc card SPI
johnny85
PostPosted: Thu Aug 26, 2010 3:27 am     Reply with quote
I want help for my thesis. I want to make a datalogger and I want to save all the data in mmc card in text format. All the project has been made, the only problem is the storage! Can someone help me!
Thank you in advance!
andrewg
PostPosted: Thu Aug 26, 2010 4:29 am     Reply with quote
Have a look at "ex_fat.c" in the CCS Examples folder.
Andrew
johnny85
PostPosted: Thu Aug 26, 2010 11:56 pm     Reply with quote
this example has a lot of things inside, i am a little bit confused!
do you have a simple example?
the only thing that i want is something like this:
1.take data from sensors(done)
2.write to sd(not done)
PostPosted: Fri Aug 27, 2010 12:17 am     Reply with quote
ex_fat.c has more than you need, but when you browse through it there is a lot you can learn from it. Just throw away all the things you don't need.
Basically all you need is shown in the function AppendFile(). This opens a file, writes data to it and then closes the file.
Potential problems are in the details. You can only write data to the card when it is formatted as FAT (either FAT16 or FAT32). Formatting can be done by the ex_fat example code or on your PC. I recommend using the format command from the example code because the CCS FAT driver is known to have problems reading Master Boot Records (MBR) when formatted on some PC's.
johnny85
PostPosted: Fri Aug 27, 2010 12:18 am     Reply with quote
Thank you a lot!
I will try it!
andrewg
PostPosted: Fri Aug 27, 2010 7:07 am     Reply with quote
...and I've posted a thread with the simple fix for that.
Andrew
newguy
PostPosted: Fri Aug 27, 2010 7:12 am     Reply with quote
Throw it in the Code Library too. Easier to find stuff like this there, and it definitely deserves to be there.
andrewg
PostPosted: Fri Aug 27, 2010 7:16 am     Reply with quote
Done. I probably should have just posted it there in the first place.
Andrew
asmallri
PostPosted: Sat Aug 28, 2010 5:41 am     Reply with quote
You may be interested in my FAT file system implementation. It has been used by several students for their thesis (with permission from their supervisors). The driver includes a full featured data logger.
Regards, Andrew
