UART for non standard baud rate
tumrobot
PostPosted: Wed Aug 25, 2010 12:05 am     Reply with quote
Hi
Can I use uart for non standard baud rate?
#include <18F458.H>
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
#use rs232(baud=10400, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
Or do I need to create non standard function by myself ?
PostPosted: Wed Aug 25, 2010 1:23 am     Reply with quote
The PIC processors can generate many non standard baud rates. The possible baud rates depend on your clock frequency and processor model. See the datasheet for examples.
The CCS compiler will generate an error message on compilation when the nearest possible frequency is more than 3% off. So, short answer, if the compiler doesn't complain your baud rate is possible.
P.S.: for a PIC18 at 20MHZ it most likely will generate a baud rate of 10417, an error of +0.16%
jbmiller
PostPosted: Wed Aug 25, 2010 5:09 am     Reply with quote
Sure can ! Work 'backwards',do the math to find a crystal and dividers to get what YOU need.
I've done it for years as an 'antihacker' ploy. real hard to lock onto serial data at 8003 baud !
Just remember that basic timing won't be 'standard'( ie 4Mhz xtal= 1 us/cycle).
Gabriel
PostPosted: Wed Aug 25, 2010 7:37 am     Reply with quote
Hmm.... so acording to all previous posts, i can assume that i can implement MIDI !!!! its got a "wierd" baud rate as well (31250 bps)....
using a 1Mhz crystal / div 32? .... i dont really know how my pic's uart goes from 20Mhz to 9600bps
@jbmiller: if its not to much trouble could you explain a bit more on the math part?
sorry to parachute my way into this post Confused
CCS PCM 5.078 & CCS PCH 5.093
Gabriel
PostPosted: Wed Aug 25, 2010 8:57 am     Reply with quote
never mind.....
PCM had a previous post on this....
thanks anyways...
tumrobot
PostPosted: Sun Aug 29, 2010 10:51 am     Reply with quote
I try to interface MCU to PC by use RS-232 baudrate 10400 at MCU and use Docklight Scripting V1.8 ser baudrate 10400 also.
I think it not working Crying or Very sad
Here is my code
#include <18F458.h>               // Standard Header file
#fuses HS,NOWDT,NOPROTECT,NOLVP      // Configuration word
#use delay(clock=20000000)           // oscillator
#use rs232(baud=10400 ,xmit=pin_c5,rcv=pin_c4,stream=HOSTPC,errors)
    while (TRUE)                  // Loop  nothing
      fprintf(HOSTPC,"\r\n*** Test UART ***\r\n");
So somebody have non standard baudrate function for RS-232?
andrewg
PostPosted: Sun Aug 29, 2010 11:01 am     Reply with quote
Is the baud rate 10400 or 104000? Your post mentions both.
Andrew
bkamen
PostPosted: Sun Aug 29, 2010 11:49 am     Reply with quote
Look at PDF page 187 of the datasheet for the PIC. It shows how to calculate the error for the desired bit rate.
tumrobot
PostPosted: Sun Aug 29, 2010 10:39 pm     Reply with quote
# andrewg
Sorry i need to use buad rate 10400
#bkamen
CALCULATING BAUD RATE ERROR
TABLE 18-1: BAUD RATE FORMULA
TABLE 18-2: REGISTERS ASSOCIATED WITH BAUD RATE GENERATOR
Desired Baud Rate = FOSC/(64 (X + 1))
Solving for X:
X = ((FOSC/Desired Baud Rate)/64) – 1
X = ((20000000/10400)/64) – 1
X = [29.048] = 29
Calculated Baud Rate = 20000000/(64 (29 + 1))
= 10416
Error = (Calculated Baud Rate – Desired Baud Rate)
Desired Baud Rate
= (10416 – 10400)/10400
= 0.001538%
from the calculation should be working but i still can't comunication with 10400 buadrate Rolling Eyes
bkamen
PostPosted: Sun Aug 29, 2010 11:53 pm     Reply with quote
do you have an oscilloscope to check the output timing?
-Ben
PostPosted: Mon Aug 30, 2010 12:40 am     Reply with quote
Here you have changed the I/O pins from the hardware UART connections to other I/O pins. Why???
It should still work as the CCS compiler will create a software UART, but this comes with limitations that you should be aware of. For one, the hardware baudrate generator that you still refer to is not being used anymore and you lost the ability to use UART interrupts.
Is the program you posted the exact same program you are testing with?
I recommend you change the pins to the original C6 and C7 so the hardware UART is being used.
