PIC16F1937: Select which timer is used for PWM
martinn
PostPosted: Wed Aug 25, 2010 2:28 am     Reply with quote
On the 16F193x devices, Timer 2, 4 or 6 can be selected for PWM:
22.3.3 TIMER2/4/6 TIMER RESOURCE
The PWM standard mode makes use of one of the 8-bit
Timer2/4/6 timer resources to specify the PWM period.
Configuring the CxTSEL<1:0> bits in the CCPTMRSx
register selects which Timer2/4/6 timer is used.
How can I select those using setup_ccpx?
- Martin
PostPosted: Wed Aug 25, 2010 3:39 am     Reply with quote
Look in the include file for the processor.
Section entitles 'constants used for SETUP_CCPx() are:'
As an example:
SETUP_CCP1(CCP_PWM | CCP_TIMER2);
