I need help!! (i2c, picdem 2 board)
choosujin
PostPosted: Tue Aug 24, 2010 8:17 pm     Reply with quote
Sad
Sorry, i'm not english native.
I need help!!
this is my code to operate termperature sensor!!
It does not work!! T^T
Help me!! what is going on my code?
I think, is it i2c setting wrong?
Result is 0xff...always,...help!! Question Question Exclamation
I used PICDEM 2 PLUS board, PIC16F877A ,ccs-c, mplab 7.31
#include <16F877A.H>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP,nocpd,nolvp
#use delay(clock = 4000000)
#include "flex_lcd.c"
#use i2c(master,sda=PIN_C4,scl=PIN_C3,FAST)
int8 temp;
void lcd_out(int8 j);
//void ch();
   unsigned   char cmd_byte=1;
   //int i;
   lcd_init();      //lcd init
   i2c_start();
   i2c_write(0X9A);
   i2c_write(cmd_byte);
   i2c_start();   //restart.
   i2c_write(0X9B);
   //i2c_write(0);
   i2c_stop();
   lcd_out(temp);
   lcd_init();
   lcd_gotoxy(1,1);
   lcd_putc("Temperature!!\n");
   lcd_gotoxy(1,2);
   printf(lcd_putc, "temp: %u(Degree)",  j );
PostPosted: Tue Aug 24, 2010 8:53 pm     Reply with quote
Download the TC74 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/21462c.pdf
Look on page 8, in this section:
TABLE 4-1: COMMAND BYTE
DESCRIPTION
What command byte should you send to read the temperature ?
What are sending ? Look at your code.
choosujin
THANK YOU!! THANK YOU!!
PostPosted: Tue Aug 24, 2010 11:24 pm     Reply with quote
DESCRIPTION
THANK YOU!! THANK YOU!! THANK YOU!! Very Happy
It does work!!! Smile
