strcpy() disables interrupts?
equack
PostPosted: Mon Aug 23, 2010 6:31 pm     Reply with quote
I tried to post this earlier but it didn't seem to take. Let's try it again:
The strcpy() function disables interrupts (see listing excerpt below). So does the sprintf() function. Is there any way to prevent this? I can't miss an interrupt. I would like to be able to use sprintf().
Thank you!
....................    strcpy(&console[116],"EQUACK 80"); // centered at the top of the screen
005FA:  MOVLW  console>>8
005FC:  MOVWF  FSR0H
005FE:  MOVLW  console+-140
00600:  MOVWF  FSR0L
00602:  MOVFF  INTCON,@@26
00606:  BCF    INTCON.GIE
00608:  MOVLW  00
0060A:  RCALL  010C
0060C:  TBLRD*-
0060E:  TBLRD*+
00610:  MOVF   TABLAT,W
00612:  MOVWF  POSTINC0
00614:  IORLW  00
00616:  BNZ   060E
00618:  BTFSC  @@26.7
0061A:  BSF    INTCON.GIE
PostPosted: Tue Aug 24, 2010 3:47 am     Reply with quote
What chip?.
There is an erratum on some chips regarding the table instructions and interrupts. Looks like a fix for this.
Remember you won't 'miss' an interrupt, it'll just be delayed for a few machine cycles.
equack
PostPosted: Tue Aug 24, 2010 10:13 am     Reply with quote
Chip is 18F26K20 running at 57.27 mHz
14.318 mHz crystal using fuse H4 for 4X PLL
Compiler is 4.095, 49243 (newer ones are broken- unrelated to this)
"it'll just be delayed for a few machine cycles".
That's the point. I cannot delay interrupts for a few machine cycles. I wrote the ISR in assembly. I had to use this PIC because it can run at up to 64mHz- earlier PICs aren't fast enough. I had to use NOPs in order to get the ISR timing just right.
And I got it working perfectly.
It stopped working when I added a sprintf() to my non-interrupt code. I thought sprintf() was the culprit so I switched to strcpy(). No Joy.
Is there a workaround? Can I link with an older version of the library or something?
I don't want to switch compilers but that's where this is headed.
equack
another sprintf() issue
PostPosted: Tue Aug 24, 2010 11:39 am     Reply with quote
I found another serious problem with sprintf().
This produces correct output:
for(;;)
   sprintf(&console[CONSOLELAST],"Line: %ld, Random: 0x%04lx",count++,rand());
output:
Line: 14, Random: 0x3886
Line: 15, Random: 0x050b
Line: 16, Random: 0x6de5
This does not:
char formstring[]="Line: %ld, Random: 0x%04lx";
for(;;)
sprintf(&console[CONSOLELAST],formstring,count++,rand());
output:
Line: %ld, Random 0x%04lx
The help file says:
sprintf(string, cstring, values...)
string is an array of characters
cstring is a constant string or an array of characters null terminated.
Values are a list of variables separated by commas.
sprintf() does no formatting if cstring is an array of characters. It only does formatting if cstring is a constant string.
collink
Re: another sprintf() issue
PostPosted: Tue Aug 24, 2010 12:12 pm     Reply with quote
for(;;)
output:
This does not:
for(;;)
output:
The help file says:
I have noticed that too (w/ 4.104 compiler PCH). If you do not pass a constant string for the format string it will ignore the formatting and just display it. I'm pretty sure they all do it: printf, sprintf, etc. Anything that takes a format string must be passed a const char string.
PostPosted: Tue Aug 24, 2010 12:25 pm     Reply with quote
Compiler is 4.095
That's an older version. Newer versions are different.
Here's my test program. It's got your strcpy line, and it's got an interrupt
routine so the compiler will be prompted to disable interrupts (if it's going
to do that).
#include <18F26K20.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#int_ext
void int_ext_isr(void)
char c;
c = 0x55;
main()
int8 console[200];
Here's the vs. 4.095 code. It does a BCF on the GIE bit. That's what
you got.
000F2:  CLRF   FSR0H
000F4:  MOVLW  console+116
000F6:  MOVWF  FSR0L
000F8:  MOVFF  INTCON,@@E0
000FC:  BCF    INTCON.GIE  // Disable global interrupts
000FE:  MOVLW  00
00100:  RCALL  009E
00102:  TBLRD*-
00104:  TBLRD*+
00106:  MOVF   TABLAT,W
00108:  MOVWF  POSTINC0
0010A:  IORLW  00
0010C:  BNZ   0104
0010E:  BTFSC  @@xE0.7
00110:  BSF    INTCON.GIE // Re-enable them if they were enabled before
Here I've re-compiled it with vs. 4.111 (the latest). It doesn't do it.
000F8:  CLRF   FSR0H
000FA:  MOVLW  console+116
000FC:  MOVWF  FSR0L
000FE:  MOVLW  00
00100:  RCALL  00AE
00102:  TBLRD*-
00104:  TBLRD*+
0010A:  IORLW  00
0010C:  BNZ   0104
Also, I commented out the #nolist line at the top of the 18F26K20.h file
so it would show me all the code in the .LST file. Here's the text fetch
code that it calls at AE. It doesn't disable interrupts either.
000AE:  CLRF   TBLPTRH
000B0:  ADDLW  BE
000B2:  MOVWF  TBLPTRL
000B4:  MOVLW  00
000B6:  ADDWFC TBLPTRH,F
000B8:  TBLRD*+
000BA:  MOVF   TABLAT,W
000BC:  RETURN 0
000BE:  DATA 45,51
000C0:  DATA 55,41
000C2:  DATA 43,4B
000C4:  DATA 20,38
000C6:  DATA 30,00
I suggest that you upgrade.
for(;;)
Read this post about why variable format strings don't work in CCS:
http://www.ccsinfo.com/forum/viewtopic.php?t=34513&start=9
equack
PostPosted: Tue Aug 24, 2010 1:46 pm     Reply with quote
Interrupt problem solved with upgrade to compiler 4.111.
Thank you!
