MPPT using PIC16F877A
Lee_831
PostPosted: Mon Aug 23, 2010 5:37 am     Reply with quote
Surprised
pmuldoon
PostPosted: Mon Aug 23, 2010 8:17 am     Reply with quote
Can't explain the SIM thing, but just a comment:
You will be happier if you put the delay back in after switching AD channels.
Make sure the source impedance is <5K or so and delay for 10-20uS (micro, not milli) should be fine. You can go a bit tighter it just depends on your circuit - the rest is in the AD section of the Datasheet.
PostPosted: Mon Aug 23, 2010 8:41 am     Reply with quote
Also note that your pwm values, _must_ be passed to the set_pwm function, as _long_ integers, not 8bit values.
set_pwm1_duty((int16) pwm);
Otherwise your PWM range is only 0-13, not 0-49....
Lee_831
PostPosted: Mon Aug 23, 2010 12:21 pm     Reply with quote
Confused
PostPosted: Mon Aug 23, 2010 12:56 pm     Reply with quote
See this thread for links about invoking 10-bit PWM mode:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729&start=12
Lee_831
PostPosted: Mon Aug 23, 2010 1:18 pm     Reply with quote
Arrow
PostPosted: Mon Aug 23, 2010 2:38 pm     Reply with quote
The 'L' is for a constant. You're passing a variable, so casting it to a int16
is the correct way. The way that you posted is correct.
