jcec
32MHz internal clock not working with PIC16F1827 |
Posted: Sat Aug 21, 2010 11:12 am |
I am programming a PIC16F1827, and using PCM compiler V4.109, 53252.
I want to operate at 32 MHz with internal oscillator, but I am obtaining behavior of 8MHz. I suspect PLL 4x is not working...
I am using the following directives / programming:
#include <16F1827.h>
#device adc=8
#fuses INTRC_IO,PLL,WDT,PUT,PROTECT,CPD,BROWNOUT,NOMCLR
#fuses NOIESO,NOFCMEN,NOCLKOUT,NOLVP,NODEBUG,BORV25,NOSTVREN
#use delay(CLOCK=32000000,RESTART_WDT)
#use fast_io(A)
#use fast_io(B)
setup_oscillator(OSC_8MHZ | OSC_PLL_ON | OSC_INTRC);
What am I doing wrong and what else can I do ?
Thank you all. |
Posted: Sat Aug 21, 2010 10:40 pm |
Post a little program that blinks an LED, that you use to prove that it's
not running at 32 MHz.
This thread has examples of LED blinking programs:
http://www.ccsinfo.com/forum/viewtopic.php?t=42223
Also, don't use WDT, PROTECT, and CPD in the test program. They are
not needed. |
jcec
OSCCON bits manually set up |
Posted: Sun Aug 22, 2010 10:38 am |
I used the following program
#device adc=8
#fuses INTRC_IO,PLL,PUT,BROWNOUT,NOMCLR
#use fast_io(A)
#use fast_io(B)
//Program pin direction
set_tris_a(0x00);
//Program oscillator
// Blink an LED on pin A2. (PIN_A2 == pin 1 on 16F1827 DIP)
output_high(PIN_A2);
output_low(PIN_A2);
This resulted in a period of 4 seconds (2s low, 2s high) of the output and not 1s as desired.
Then I added the following code line configuring SCS bits of OSCCON:
OSCCON = OSCCON & 0xFC; // OSCCON.1 = OSCCON.0 = 0;
and, voila, the output period worked fine (1s as expected for a 32 MHz)
Good, this is a solution, but I wonder what would be the right configuration to be done using only CCS C functions...
Thanks. |
bkamen
Posted: Sun Aug 22, 2010 11:12 am |
Sometimes you don't need the SETUP_OSC(); if the fuses/USE DELAY is.
See, the fuses (and then #USE DELAY) set up those config items already and then you set them again in code using SETUP_OSC();
So try this and let me know if it works:
#use delay (clock=32M, INT=8M)
Check the LST output at the CONFIG words (at the bottom of the .LST file)
If that works, then you may not even need the #FUSES PLL line.
jcec
Posted: Sun Aug 22, 2010 5:34 pm |
bkamen:
I tried what you suggested;
#device adc=8
////////#use delay(CLOCK=32000000,RESTART_WDT)
#use delay (clock=32M,int=8M)
#use fast_io(A)
#use fast_io(B)
set_tris_a(0x00);
//////// setup_oscillator(OSC_8MHZ | OSC_PLL_ON | OSC_INTRC);
output_low(PIN_A2);
but it did not work, the PLL enable bit in the configuration word does not get enabled!
Thanks. |
bkamen
Posted: Sun Aug 22, 2010 6:13 pm |
jcec wrote: | bkamen:
#device adc=8
#use fast_io(A)
#use fast_io(B)
set_tris_a(0x00);
output_low(PIN_A2);
Thanks. |
Ok, I've dug deeper for you...
PLL doesn't seem to be a valid fuse.
PLL_SW is the only fuse that's valid.
Using #use delay(clock=32M, int=8M) doesn't set the PLLEN bit in Config2 either.
The datasheet states that if CONFIG2.8 == 1
Then OSCCON.7 is ignored and the PLL is enabled.
However, there's no fuse to set CONFIG2.8 (as I readily see)
If everyone else agrees, then this is a CCS database bug and you should submit it.
You should also read the datasheets more carefully as you would have seen this.
For now, if you want your code to work the way it should, you can fuss with the software or you could set the ROM location of the config2 word to 0x19FF (which is PLL enabled)
This works: (according to MPLAB)
#rom 0x8008 = {0x19ff}
And tell CCS to look again at this device...
jcec
Posted: Sun Aug 22, 2010 8:07 pm |
Hi bkamen,
Thanks for your hints and for your time on this issue.
I´ll do as you suggest and also submit a bug report to CCS.
Best regards. |
