I2C i/o expander
SveinR
I2C i/o expander
PostPosted: Thu Aug 19, 2010 6:18 am     Reply with quote
I'm looking for an i/o expander that is controlled by i2c and has the option to invidually set the pins to in or out.
Is there any example files out there?
I'm in need of 8-10 i/o's
MikeW
PostPosted: Thu Aug 19, 2010 6:34 am     Reply with quote
2 questions :-
1. what has this got to do with the CCS C compiler
2. are you incapable of googling "I2C i/o expander"
try PCF8574
SveinR
PostPosted: Thu Aug 19, 2010 6:53 am     Reply with quote
MikeW wrote:
2 questions :-
try PCF8574
I need and example file showing how to setup this i/o expander,
and as I'm aware of there is no include file for the PCF8574 included in the CCS package that I got.
Humberto
PostPosted: Thu Aug 19, 2010 7:03 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=19526&highlight=pcf8574
Humberto
MikeW
PostPosted: Thu Aug 19, 2010 7:11 am     Reply with quote
PCF8575 is a 16 i/o device
#define PCF8575_device_type 0x40
// pcf8575 device numbers go from0 -number of devices
void  Test_IO_Module()
int16 PCF8575_Data_Word;
Digital_Inputs_from_PCF8575=read_PCF8575(0);   // get the digital input states
Display_Digital_Input_Values(~Digital_Inputs_from_PCF8575);
} // end of function
// functions
// this is a handy function for taking the i2c physical address
// and shifting the bits left so that the address can simply be
// OR'd with an i2c write command...
int i2c_addr_mask(int device_addr)
   /* xxxxxIJK --> 00000IJK, then 00000IJK --> 0000IJK0 */
   return((device_addr & 0x07)<<1);
#define I2CWRITE     0b00000000
#define I2CREAD      0b00000001
void write_PCF8575(BYTE device_address, WORD data)
BYTE Upper_Data_Byte;
BYTE Lower_Data_Byte;
BYTE addr_mask;
BYTE address;
   addr_mask=i2c_addr_mask(device_address);
   i2c_start();
   Upper_Data_Byte=make8(data,1);
   Lower_Data_Byte=make8(data,0);
   i2c_start();
   address=(PCF8575_device_type | addr_mask | I2CWRITE);
   i2c_write(address);
   i2c_write(lower_Data_Byte); // LSB 1 is input mode
   i2c_write(~Upper_Data_Byte); // MSB 1 is OFF , inverted 'cos of the HC240
   i2c_stop();
int16 read_PCF8575(BYTE device_address)
BYTE addr_mask;
BYTE address;
   i2c_start();
   address=(PCF8575_device_type | addr_mask | I2CREAD);
   i2c_write(address);
   Lower_Data_Byte=i2c_read(); // LSB get the byte
   Upper_Data_Byte=i2c_read(0); // MSB get the byte
   i2c_stop();
   return (make16(Upper_Data_Byte,Lower_Data_Byte));
SveinR
PostPosted: Thu Aug 19, 2010 7:24 am     Reply with quote
Thanks all Very Happy
