adding values to a text string
vinniewryan
PostPosted: Wed Aug 11, 2010 10:06 pm     Reply with quote
I have a basic question,
I'm trying to read the inputs of 3 ADC pins on my PIC16F684, and save them all to one text string that will then be sent to an LCD using RS232 communication. My question is, it there a way to add values to a text string?
For example, this is what I want to do:
set_adc_channel(1);
VAR=read_adc(); //let's pretend ADC reads 103
//ADD VAR to text string, followed by a comma. Now text string should read "103,"
set_adc_channel(2);
VAR=read_adc(); //let's pretend ADC reads 244
//ADD VAR to text string, followed by a comma. Now text string should read "103,244,"
set_adc_channel(3);
VAR=read_adc(); //let's pretend ADC reads 77
//ADD VAR to text string, followed by a comma. Now text string should read "103,244,77,"
putc("text string"); //send text string to LCD via RS232
So the LCD should receive "103,244,77,". Is this possible? I want to use my PIC as a data logger, but I don't want to create an identifier for every value being recorded. I would prefer to save all recorded values in a CHAR array that can be sent to the LCD in one 'putc' command.
The code, when finished, will record data from the ADC inputs 5 times per second for 5 seconds, so it would take 25 identifiers to accomplish this, and that's just a sloppy way to do this.
Thanks!
Vinnie Ryan
Audi80
PostPosted: Thu Aug 12, 2010 6:46 am     Reply with quote
Hi there, the simplest thing to do is use strcat
Ex:
char completeString[100];
void addValue(char * newAdcValue){
    strcat(completeString,newAdcValue);
    printf("Whole new String: %s\r\n",completeString);
Test it and see if it works, best regards...
PostPosted: Thu Aug 12, 2010 6:55 am     Reply with quote
I don't understand why you can't write each part to the LCD separately.
Instead of strcat you could use printf:
set_adc_channel(1);
var1=read_adc(); //let's pretend ADC reads 103
set_adc_channel(2);
var2=read_adc(); //let's pretend ADC reads 244
set_adc_channel(3);
var3=read_adc(); //let's pretend ADC reads 77
printf("%d,%d,%d,", var1, var2, var3);  //send text string to LCD via RS232
PostPosted: Thu Aug 12, 2010 7:55 am     Reply with quote
A series of comments:
1) The ability to send a multi-character string with putc, _only_ applies to constant strings. The string will need to be printed out a character at a time, or sent with puts/printf.
2) As another poster has said, why not just printf the values. If you are worried about timing, consider using buffered interrupt driven transmit (ex_stisr.c), and print to this.
3) if you must have a string, you can generate it, using sprintf, in one go, or if you 'must' do it a section at a time, generate it in parts, then assemble using strcat.
vinniewryan
PostPosted: Fri Aug 13, 2010 2:26 pm     Reply with quote
compiler version 4.0.3
After trying all mentioned methods, I decided to just pay $0.60 for a memory chip. I didn't realize they're so cheap! So now that problem is solved.
Which brings me to my new problem, which I'm currently researching. I can't seem to send an int16 via printf or puts. This is the context:
//un-important setup stuff here
#use RS232(BAUD=19200,INVERT,LONG_DATA,FORCE_SW,XMIT=pin_a0)
long X;
X=Read_ADC();
puts("%d", X);
printf("%d", X);
when I set X as a LONG (16 bit), the compiler gives me an error "Print format type is invalid". When I set X as 'char', the compiler returns no errors, but only outputs 8 bits.
I need 16 bit values to be sent to my LCD but the compiler won't let me do this with my current methods.
Any ideas?
Vinnie Ryan
PostPosted: Fri Aug 13, 2010 2:32 pm     Reply with quote
I need 16 bit values to be sent to my LCD but the compiler won't let me do this.
It will, and it's in explained in the CCS manual.
Look in the printf section of the manual. There is a table of format
values to use, to display any data type (including 16-bit). In the June
2010 manual, this is on page 207 (page 219 in the acrobat reader).
vinniewryan
PostPosted: Fri Aug 13, 2010 2:43 pm     Reply with quote
Thank you PCM, you just solved my problem! I overlooked the table, thanks for the info!
Vinnie Ryan
