rnd87
| Connection or source code problem?? |
Posted: Wed Aug 11, 2010 1:45 am |
I have used these codes for RS485 communication.(Based on RS485.c)But I couldn't understand where is the problem source code or hardware;
Master RS485 codes;
#include <16F877.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use delay(clock = 4000000)
#define RS485_ID 0x10 // The device's RS485 master address
#define RS485_USE_EXT_INT TRUE // Select asynchronous serial interrupt
#include <RS485.c>
int buffer[40];
int next_in = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
int t;
buffer[next_in] = fgetc(RS485);
t = next_in;
next_in = (next_in+1) % sizeof(buffer);
if(next_in == next_out)
next_in=t; // Buffer full !!
int j;
int data_received[32];
enable_interrupts(INT_RDA);
rs485_init();
rs485_wait_for_bus(FALSE);
//send address=0x11, length = 1, msg=3
//the led does blink here
if(rs485_send_message(0x11, 1, 3))
output_low(PIN_B1);
output_high(PIN_B1);
output_low(PIN_B1);
delay_ms(5);
if(rs485_get_message(data_received, FALSE))
for(j=0; j<3; ++j)
data_received[j] = buffer[j];
if(data_received[2]==6) //if slave receives the number 3 successfully
{ //slave will send back number 6
output_low(PIN_B2);
output_high(PIN_B2);
output_low(PIN_B2);
Slave RS485 codes;
#include <16F877.h>
#define RS485_ID 0x11 // The device's RS485 slave address or ID
#include <RS485.c>
int buffer[40];
int next_in = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
int t;
t = next_in;
int i=1;
int j;
rs485_init();
if(rs485_get_message(data_received, TRUE))
for(j=0; j<3; ++j)
if(data_received[0] == 0x11)
output_low(PIN_B2);
output_low(PIN_B2);
//after receive successfully, respond to master by sending number 6
if(rs485_send_message(0x10, 1, 6))
output_low(PIN_B1);
output_low(PIN_B1);
And here is my hadware;
FvM
Posted: Wed Aug 11, 2010 2:04 am |
| You didn't mention an actual problem. Is it a guessing game? |
rnd87
Posted: Wed Aug 11, 2010 3:18 am |
| OK sorry, My problem is about communication. I couldn't get any result at slave side. I couldn't see any changing at RB1 and RB2. The message has not been send by these system. |
jbmiller
Joined: 07 Oct 2006 Posts: 73 Location: Greensville,Ontario
Posted: Wed Aug 11, 2010 5:09 am |
| I don't see any bias resistors in the RS-485, or a common ground....in the schematic. |
Posted: Wed Aug 11, 2010 8:53 am |
| Interrupts only work when you are using the hardware UART for receiving and transmitting the data. The hardware UART is connected to pins C6/Tx and C7/Rx, not to your B0 and B3. |
