Andreas
| Exit a for loop ?? |
Posted: Wed Aug 11, 2010 8:22 am |
Hi friends,
A new question comes up during coding today:
Is it possible to exit a for loop ?
I just want to run an infinite loop with a check of a Value and if this value gets true the for loop should be exit.
Is this possible in CCS C ?
best regards
Andreas |
collink
| Re: Exit a for loop ?? |
Posted: Wed Aug 11, 2010 8:26 am |
| Andreas wrote: | Hi friends,
I just want to run an infinit loop with a check of a Value and if this value gets true the for loop should be exit.
best regards
Andreas |
Have you tried "break"? This is a very, very basic C question. Maybe you should get a book on C from the bookstore? |
rnielsen
Posted: Wed Aug 11, 2010 11:18 am |
A while() loop will work for that. You can have it evaluate whatever variable you want and when it becomes true, the while() loop exits.
Ronald |
Posted: Wed Aug 11, 2010 2:26 pm |
For both a while loop, and a for loop, the same answer applies. Break.
So:
for(;;) {
//Permanent for loop
if (condition) break;
//You get here when 'condition' goes true.
while (TRUE){
//Same comment
do {
} while (TRUE);
//and again
The important thing is that in each loop, it is perfectly possible to have an 'exit' condition in the loop criteria, but this will only be tested at the end of the loop (or start), but with 'break', you can exit the loop from a point well inside.
Humberto
Posted: Wed Aug 11, 2010 3:42 pm |
Well, to be a little more specific, the break statement terminates the do, for, switch, or while statements while is within its encloses.
Humberto |
deperkin
| complexity |
Posted: Wed Aug 11, 2010 6:33 pm |
using a break; is far too simple...
why not create a section of code to write to an external eeprom and use a WHILE to check a specific memory location for any change...
maybe add a secondary uC just to monitor changes on this external eeprom location and use i2c...
or you could just use 'break;' |
Andreas
Posted: Wed Aug 11, 2010 11:31 pm |
Hi Friends,
Thanks for this clear answers..........
The reason why I wa asking was that in the CCS Manual the break possibility for the FOR loop was not mentioned.
But anyhow evrybody can learn........
Andreas |
