Configure PIC18F4525 as modbus-slave (ex_modbus.c)
wewa
PostPosted: Mon Aug 09, 2010 9:38 am     Reply with quote
Can anyone help me to configure a PIC18F4525 as a modbus-slave. Using the ccs-example-project "ex_modbus_slave.c"?
Here's the wiring:
             PIN_B1 0------------0 1 (Receive)         RS485-Transreceiver
                    |            |                           SN75LBC184D
PIC          PIN_C5 0-------+----0 2 (Receive Enable)
18F4525             |       |    |
                    |       +----0 3 (Transmit Enable)
             PIN_D3 0------------0 4 (Transmit)
How do I have to edit the config file?
Mine looks like this:
#include <18F4525.h>
//#device *=16
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT, MCLR
#define MODBUS_TYPE MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_RX_BUFFER_SIZE 64
#define MODBUS_SERIAL_BAUD 9600
#ifndef USE_WITH_PC
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_EXT
#define MODBUS_SERIAL_TX_PIN PIN_D3   // Data transmit pin
#define MODBUS_SERIAL_RX_PIN PIN_B1   // Data receive pin
//The following should be defined for RS485 communication
#define MODBUS_SERIAL_ENABLE_PIN   PIN_C5   // Controls DE pin for RS485
//#define MODBUS_SERIAL_RX_ENABLE    0   // Controls RE pin for RS485
#else
#include "modbus.c"
I got this ex_modbus_slave.c working with a PIC16F87A (using the Pins B0, B1 and B2 of the pic). But with the PIC18F4525 I have problems.
Thanks for any help.
PostPosted: Mon Aug 09, 2010 11:59 am     Reply with quote
The logical thing to do, if it works on a 16F but fails on an 18F would be to:
1. Look for hard-coded register addresses in the code, because they
are different between the two PIC families. I didn't see any of that.
2. Next, look for differences in pin features. Maybe the pins that are
used on a 16F are input-only on the 18F, or some other difference.
So I noticed that ex_modbus_slave.c has these pin definitions.
#else
#define MODBUS_SERIAL_TX_PIN PIN_B1 // Data transmit pin
#define MODBUS_SERIAL_RX_PIN PIN_B0 // Data receive pin
These aren't the hardware pins, so they're using a software UART.
I then wondered strongly if they are using #int_ext to do interrupt-driven
reception of the incoming bytes. That interrupt is available on Pin B0.
So I looked in the modbus.c and found that yes, they are using INT_EXT
for pin B0.
// Purpose: Interrupt service routine for handling incoming serial data
// Inputs: None
// Outputs: None
#elif (MODBUS_SERIAL_INT_SOURCE==MODBUS_INT_EXT)
#if defined(__PCD__)
#int_ext0
#else
#int_ext
Then I go back to your code and see that you have changed the Rx pin
into B1, which does not have the #int_ext interrupt on it.
Now, it does have another interrupt on it. It has #INT_EXT1.
You could edit modbus.c to use #int_ext1 instead of #int_ext.
But in my opinion it would be a lot cleaner and easier just to change
your hardware to use pin B0. Then you don't have to edit the driver code.
wewa
PostPosted: Mon Aug 09, 2010 1:12 pm     Reply with quote
Thanks for your reply.
I think in the default configuration of ex_modbus_slave.c the interrupt is not used. Because interrupt is only used, when MODBUS_SERIAL_INT_SOURCE is set to MODBUS_INT_EXT. But in ex_modbus_slave.c MODBUS_SERIAL_INT_SOURCE is set to MODBUS_INT_RDA. (I think they are using software UART.)
wewa
PostPosted: Tue Aug 10, 2010 7:57 am     Reply with quote
Sorry I was wrong, you were right.
By default MODBUS_SERIAL_INT_SOURCE is set to MODBUS_INT_EXT.
I don't have the possibility to use PIN_B0 instead of PIN_B1. Therefore I need to tell the program to use INT_EXT1.
But it seems that the program never goes into interrupt. Why? (I have changed all parts of ex_modbus_slave.c from INT_EXT to INT_EXT1 and ext_int_edge(H_TO_L); to ext_int_edge(1, H_TO_L);. Do I need to make further changes?
PostPosted: Tue Aug 10, 2010 1:46 pm     Reply with quote
Look at the .LST file to make sure that it's being compiled the way that
you want it to be. Look in the .LST file to see if an #int_ext1 routine
exists (look for the ASM code).
wewa
PostPosted: Wed Aug 11, 2010 1:18 am     Reply with quote
I'm a fool.
You gave me the tip how to solve my problem. It was a really simple problem.
In the .LST file I saw that #int_ext1 not exists. And than i noticed that in ex_modbus_slave.c modbus.c was included. And I edited the file ex_modbus.c ......... Now it works.
Thank you very much for your help and patience.
