ROM listing debugger?
equack
PostPosted: Wed Aug 04, 2010 12:05 pm     Reply with quote
I'm using V4.095 of the IDE with an ICD-U64. I compile for debug and everything works fine- I can single step, set breakpoints, use the eval() tab to examine variables, etc.
EXCEPT: when I look at the ROM() tab all I get is a list of addresses with no data. I'm trying to debug a ROM based look up table so I really need to see this.
It's a PIC18F2455 if it matters. I'm only using PGC and PGD on the ICSP connection- I do not have PGM (RB5) connected. Would it help?
The help file says the ROM display comes from the HEX file and is not read directly from the device.
What am I doing wrong?
I have also found that the C/ASM listing generated by the compiler does not include all of the code. For example, I have declared an array:
const char font48[]={0x00,0xff, repeat for ~6500 bytes};
When I look at the assembly code for:
base=font48[long index];
I see
  MOVLB     0
  CALL        13E2
  TBLRD*+
but there is no assembly code at "13E2" in the listng.
PostPosted: Wed Aug 04, 2010 2:34 pm     Reply with quote
Sometimes you need to comment out the #nolist statement at the start
of the .h file for your PIC, in order to see all the code in the .LST file.
Also, with 'const' tables, you may not see all the code for the following
reasons:
1. If two or more entries (rows) of constants are the same, the compiler
will only put code into ROM for one set. That's done to save ROM.
It's optimizing the code.
2. If you access the array with a constant index value (a number, not
a variable), the compiler will load the value as an immediate value,
with the MOVLW instruction. The table won't be put into ROM.
3. To have the whole 'const' array put into ROM, you need to access it
with a variable as the index. Then the compiler has no way to know the
value that's being accessed at compile-time. It can't optimize it into a
MOVLW. It has to put the whole table into ROM.
equack
still no ROM data
PostPosted: Wed Aug 04, 2010 3:55 pm     Reply with quote
Comment out the "#define NOLIST" line in my 18F2455.h file solved part of the problem. Now I can see the "missing" assembly code in the listing file.
Thank you!
I still cannot see anything when I switch to the debugger's ROM tab. The RAM and Data EE tabs work properly but the ROM tab just shows a list of addresses but no data.
Do I have to do something special to load the HEX file into the debugger?
PostPosted: Wed Aug 04, 2010 4:16 pm     Reply with quote
I don't have the CCS ICD-U64 debugger so I can't help on that.
