turn high 2-3 port at the same time
takumi
PostPosted: Wed Aug 04, 2010 12:37 am     Reply with quote
#define SW1 PIN_B0
#define SW2 PIN_C5
#define BUZZER PIN_D6
#define LED1 PIN_D7
#define LED2 PIN_E2
void main(){
   while(1){
      if(!input(SW1) && input(SW2)) output_high(LED1);
      else if (input(SW1) && !input(SW2)) output_high(LED2);
      else if(!input(SW1) & !input(SW2)){
       output_d(0b11000000);
       output_high(LED2);
      else {
         output_low(LED1);
         output_low(LED2);
         output_low(BUZZER);
Hi all, is there any method to turn on both LED1 & Buzzer at the same time?
I have tried to use:
output_high(LED1);
output_high(LED2);
output_high(BUZZER);
But the simulation in Proteus shows the LED1 & BUZZER just blinking.
But if I used the code as below, both turn high:
Why does this thing happen? Any idea? Please help.
PostPosted: Wed Aug 04, 2010 1:54 am     Reply with quote
Search for previous threads about RMW (read-modify-write) issue.
In a short, it happens because you are overloading the pins, so that the output high level is below specified minimum input high value.
takumi
PostPosted: Wed Aug 04, 2010 6:11 am     Reply with quote
tq.. found the solution already. Just add 330 resistor before the LED.
