Determining PWM duty cycle with one pin
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Tue Aug 03, 2010 5:14 am     Reply with quote
Hi, I am thinking about how to determine the duty cycle of a incoming 5kHz TTL signal.
I have the signal connected to a CCP pin. Obviously no problem in determining the frequency. Well I say that but I am resetting timer1 in the interrupt, you can't assume that the interrupt will occur at a fixed time after the capture...there must be a way around that?
A solution for duty may be to switch from RE to FE detection after the interrupt but it doesn't seem very neat, and so math will be required in the interrupt routine slowing it down (although probably not an issue in this case).
Any good ideas. This must be a common(ish) application for the CCP module?
PostPosted: Tue Aug 03, 2010 12:19 pm     Reply with quote
Here are examples of various ways to measure a pulse.
Using CCP:
c:\program files\picc\examples\ex_ccpmp.c
Using a Timer:
c:\program files\picc\examples\ex_pulse.c
Using software counting loops:
http://www.ccsinfo.com/forum/viewtopic.php?t=42353
Mike Walne
Measuring PWM
PostPosted: Thu Aug 05, 2010 3:41 pm     Reply with quote
Two possible methods
1) Make the amplitude of the input signal the same as your PIC power rails, process with a low pass filter, and apply to one of the analogue input pins. The ADC measures the duty ratio directly.
2) Sample the input signal at random intervals. Over a period of time the ratio (Total Number of 1's / Total Number of samples) is your duty ratio. The trick here is to make sure that you do NOT synchronise your sampling to the input signal. Increasing the number of samples gives a more accurate result.
Mike Walne
