XBee PIC18F4520
ilato88
XBee PIC18F4520
PostPosted: Sun Aug 01, 2010 7:18 pm     Reply with quote
Hi i am new to using PIC microcontrollers and wireless modules. I have decided to use the XBee modules since it says that by default, out of the box they are serial port replacements to communications.
I am using the CCS compiler with the 2 PIC18F4520 running on 5V, 2 XBee 1mW modules on 3.3V. The goal is to establish a simple connection from one PIC to the other PIC using XBee.
The simple code works when the 2 PICS are connected to each other from the Transmit Pin and Receive Pin and works perfectly. My understanding is that instead of connecting the Transmit and Receive to each other I connect them to the XBee and the same code should communicate.
I have not gotten it to work using a variety of different configurations and have gotten a bit frustrated. The whole circuitry for both are running on the same supply right now, i have tried using resistors from the PIC Tx and Rx, as i have seen some configurations with them included. From my understanding if they are communicating PIC to PIC they should communicate PIC to XBee to XBee to PIC.
Here is the simple code i am testing.
The first code to PIC is to transmit:
/* pic2pic_transmit.c
The transmitter checks to see if PIN A0 is high or low.
If the  pin is high, the transmitter sends the signal 'a' to the receiver and
turns on an LED. If the pins is low, the transmitter sends the signal 'b'.
#include <18f4520.h>
#fuses HS,NOLVP,NOWDT,NOPROTECT
#use delay(clock=20000000)       // 20 MHz crystal on PCB
#use rs232(baud=9600, UART1)
#include <stdlib.h>
#define LED_0 PIN_D0
   while (TRUE) {
      if (input(PIN_A0)){
         output_high(LED_0);
         printf("a"); //sends signal a
       else{
         output_low(LED_0);
         printf("b"); //sends signal b
The second code is set on the other PIC to receive:
/* pic2pic_receive
The receiver checks the signal from the XBEE and if the signal is 'a', the receiver turns on an LED.
#include <stdlib.h>
char x;
   while (TRUE) {
       if (kbhit()) {
         x = getc();
       if (x=='a'){
         output_high(LED_0);
       else{
         output_low(LED_0);
Thanks in advance for any help!
asmallri
Re: XBee PIC18F4520
PostPosted: Sun Aug 01, 2010 10:23 pm     Reply with quote
ilato88 wrote:
The whole circuitry for both are running on the same supply right now...
Hopefully you mean everything is running from 3.3 volts. If you power a Xbee module from 5 volt you may destroy it.
They almost works out of the box. You have to configure each unit with its local address and the address of the target (remote) unit. Let's say you have two units, A and B. On A you will configure its address as 0 and the remote (B unit) as 1. Then on module B you will configure Module B's address as 1 and the remote unit as 0. Now anything you transmit on A will be received on B and visa versa.
Regards, Andrew
