Parse Clock and Data from Cardswipe
adamp524
PostPosted: Tue Jul 27, 2010 10:02 am     Reply with quote
I'm using a magnetic cardswipe reader which is read using two signals: clock and data. (The cards swiped are encoded in ABA Track 2 format). The clock pin is connected to an interrupt pin on the PIC and the data is connected to a standard input.
The idea is that each time the clock pulses, the input state of the data pin is read and this data added to a buffer for processing.
How would I create a buffer that can be used to store the incoming data and be checked for a full cardswipe?
I assume that there is too much processing involved to process a full cardswipe in the interrupt routine so a secondary processing function would have to be used? Any ideas on how I could implement this?
PostPosted: Tue Jul 27, 2010 12:20 pm     Reply with quote
CCS card reader example and driver files:
c:\program files\picc\examples\ex_mcr.c
c:\program files\picc\drivers\mcr.c
Card reader thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=30921
Resources (links) for interfacing to a card reader:
http://stripesnoop.sourceforge.net/devel/index.html
adamp524
PostPosted: Wed Jul 28, 2010 2:39 am     Reply with quote
Thanks for the post, I've looked at the mcr.c file and it works well for my cardswipe BUT I need it to work without using the card present signal. Any ideas on how I could achieve this?
PostPosted: Wed Jul 28, 2010 10:47 am     Reply with quote
What is the manufacturer and model number of your reader ?
Post a link to the website for the reader.
