GPS problems
Aiden
GPS problems
PostPosted: Wed Jul 28, 2010 8:44 am     Reply with quote
Hi guys I am new to all this and ppl say this is the best site to get help with CCS (I wonder why), but jokes aside, ppl say this forum is really great so here goes.
I need only One String From The GPS and I keep on getting only the $GPRMC string.
I've connected my GPS (LEA 5h to hyperterminal and she sends the string I need as well).
I get $GPRMC. I need $GPGGA, and send it over the RFL_COM stream.
First the user enters a ID := 12345 if that is correct then wait for the correct message from GPS_COM and send it via RFL_COM at 1200 baud
Heres the code pls help me.
#include <16F627.h>
#USE DELAY( CLOCK=4000000 ) /* Using a 4 Mhz clock */
#use rs232(baud=9600,parity=N,xmit=PIN_B0,rcv=PIN_B4,bits=8, invert, stop =1, Stream=GPS_COM)
#use rs232(baud=1200,parity=N,xmit=PIN_B2,rcv=PIN_B3,bits=8, invert, stop =1, Stream=RFL_COM)
#FUSES XT
      char NEMA[83];
      char ID[6] = "12345";
      unsigned int i = 0;
/*      NEMA[0] = '$';
      NEMA[1] = 'G';
      NEMA[2] = 'P';
      NEMA[3] = 'G';
      NEMA[4] = 'G';
      NEMA[5] = 'A'; */ //The NEMA Test
         if(KBHit(RFL_COM))
            ID[i] = fgetc(RFL_COM);
            i++;
            if(i >= 4)
               i = 0;
               if((ID[0] == '1') && (ID[1] == '2') && (ID[2] == '3') && (ID[3] == '4') && (ID[4] == '5'))
                  if(KBHit(GPS_COM))
                        fgets(NEMA, GPS_COM);
                        while((NEMA[0] != '$') &&   (NEMA[5] != 'A'))
                        fputs(NEMA, RFL_COM);
                  fputs("Wrong ID", RFL_COM);
Well music maths science pics electronics and well just everything good
PostPosted: Wed Jul 28, 2010 12:50 pm     Reply with quote
Do you know for certain that your GPS transmits the GPGGA message ?
Have you tested it by connecting it to a PC, and looked at the messages
in a terminal window ?
Why are you using only software UARTs ? The 16F627 has a hardware
UART on pins B2 and B1 (Tx and Rx).
Aiden
PostPosted: Thu Jul 29, 2010 2:31 am     Reply with quote
Yes it sends 6 different strings and one is $GPGGA.
And for using 2 software uarts, I am using one of my old boards for another project, I'll build the new board and use the Hardware UART then....
With this version of the code I get $GPGGA and $GPRMC:
         fputs("GPS Processor Online \r", RFL_COM);
         while(i <=4)
            tempc[i] = fgetc(RFL_COM);
               if(i == 4)
               i = i + 1;
         if((tempc[0] == '1') && (tempc[1] == '2') && (tempc[2] == '3') && (tempc[3] == '4') && (tempc[4] == '5'))
            tempc[0] = "";
            tempc[1] = "";
            tempc[2] = "";
            tempc[3] = "";
            tempc[4] = "";
            tempc[5] = "";
            while(c[0] != '$')
                  fgets(c, GPS_COM);
                  fgets(d, GPS_COM);
            //fputs(d, RFL_COM);
            //delay_ms(2);
            //fputs(c, RFL_COM);
            fputs(c, RFL_COM);
            fputs(d, RFL_COM);
            fputs("ITAG 4 Life: ID 12345", RFL_COM);
            fputs("ID's Do Not Match", RFL_COM);
I don't know WHY???
p.s. the if test is for the ID the user inputs and
char c[83];
char d[80];
char tempc[6];
int  i;
sometimes if the pic starts up and you enter the id "12345" it just skips this section of code and goes back to the start of the while(1) loop but if you enter the ID incorrectly it says "ID's Do Not Match" ?????
                  fgets(c, GPS_COM);
                  fgets(d, GPS_COM);
            //delay_ms(2);
            fputs(c, RFL_COM);
            fputs(d, RFL_COM);
Thanks for the reply.
aiden
