Specific Timeout Rutine
Ezequiel
PostPosted: Sun Feb 02, 2003 1:11 pm     Reply with quote
In a part of my program I have to send 1 byte at 1200bps (that's no problem), and wait for 3 bytes at 9600bps. But I that bytes doesn't come in less than 2sec, I have to show a Timeout message and return to my menu. Could somebody help me with this? I'm using RS232 Inverted in a 16F73 (RC0 TX & RC1 RX)
Thanks,
Zeke
___________________________
Original Post ID: 11206
Tomi
Re: Specific Timeout Rutine
PostPosted: Mon Feb 03, 2003 2:42 am     Reply with quote
See CCS FAQ "How do I get getc() to timeout after a specified time?"
:=Hello,
:= In a part of my program I have to send 1 byte at 1200bps (that's no problem), and wait for 3 bytes at 9600bps. But I that bytes doesn't come in less than 2sec, I have to show a Timeout message and return to my menu. Could somebody help me with this? I'm using RS232 Inverted in a 16F73 (RC0 TX & RC1 RX)
:=Thanks,
:=Zeke
Original Post ID: 11221
Ezequiel
PostPosted: Mon Feb 03, 2003 7:17 pm     Reply with quote
Helo,
I looked at CCS FAQ, but I implementad that rutine in my program with no success. Is there any other way?
Thankz
Zeke
:=See CCS FAQ "How do I get getc() to timeout after a specified time?"
:=:=Hello,
:=:= In a part of my program I have to send 1 byte at 1200bps (that's no problem), and wait for 3 bytes at 9600bps. But I that bytes doesn't come in less than 2sec, I have to show a Timeout message and return to my menu. Could somebody help me with this? I'm using RS232 Inverted in a 16F73 (RC0 TX & RC1 RX)
:=:=Thanks,
:=:=Zeke
Original Post ID: 11250
Ezequiel
PostPosted: Fri Feb 07, 2003 5:55 pm     Reply with quote
I have a program where I need to stablish a comm. with a ECU (Electronic Control Unit), this unit can operate at 9600bps or 10400bps. But to start the comm. I have to send a command at 5Bps. Fortunately I can do this using Output_low and Output_High and a Delay of 200mS. Then the ECU reply with 0x55 (a good Sync Byte, but I don't know how to use it) and two Data Bytes at 9600bps or 10400bps 8Bits No Parity Inverted. The problem is that I don't know at which baudrate the ECU is going to use. I try to modify the timed_getc() rutine (which appears on a FAQ in the website) with no success. Another problem is that the rest of the program has to communicate also at this baudrate (to send and receive).
I tried to use the HUSART and Set_Usart_Speed (To change between 9600bps and 10400bps) but then I cannot send the command at 5Bps using Output_low and Output_High, at I cannot set the USART to 5Bps.
I find two possible solutions.
A) Send the command (Using any pin but not the USART) at 5Bps, and look in the SyncByte (0x55) to decide which baudrate to use.
B) Send the command (Using any pin but not the USART) at 5Bps, wait for 1.5Sec the SyncByte (0x55) at 9600bps, If it comes the rest of the program has to use this baudrate. If not, change to 10400bps, re send the command, and wait for 1.5Sec the Sync Byte at 10400bps. If it comes the rest of the program has to use this baurate, if not there is no ECU to communicate with, and goto the beginning of the program.
I would like to know if it's possible to do this, which option is more easy to implement, and if you can help me with this little rutine.
Here I send you the code (which is very short), it's unfinished but you can see which micro I'm using and so on.
Thank you very much,
Ezequiel
:=Helo,
:= I looked at CCS FAQ, but I implementad that rutine in my program with no success. Is there any other way?
:=Thankz
:=Zeke
:=:=See CCS FAQ "How do I get getc() to timeout after a specified time?"
:=:=:=Hello,
:=:=:= In a part of my program I have to send 1 byte at 1200bps (that's no problem), and wait for 3 bytes at 9600bps. But I that bytes doesn't come in less than 2sec, I have to show a Timeout message and return to my menu. Could somebody help me with this? I'm using RS232 Inverted in a 16F73 (RC0 TX & RC1 RX)
:=:=:=Thanks,
:=:=:=Zeke
Original Post ID: 11416
