RS232,16F870 problem
John
PostPosted: Mon Feb 03, 2003 7:22 am     Reply with quote
Hello!
I'm having a hard time getting the RS232 PIC/PC communication to work. PIC->PC is ok, but the PIC doesn't seem to read anything on RX even though the signal is there. Checked everything with a scope. I use a MAX232. Tried both hardware UART and software (xmit=b3, rcv=b2) but the same things happen. Tried 4/20Mhz osc with a number of different baudrates but no, it doesn't seem to read RX. Also tried removing fast_io, tris statements, adding PARITY etc but no. Now I'm running out of ideas...
This is the testprogram I've been wrestling with:
#include <16f870m.h>
#fuses HS, NOPROTECT, NOWDT, PUT, NOBROWNOUT, NOLVP
#use DELAY(clock=4000000)
#use fast_io ( A )
#use fast_io ( B )
#use fast_io ( C )
void main( void )
char Com;
set_tris_a ( 0b00000000 );
set_tris_b ( 0b00000000 );
set_tris_c ( 0b10000000 ); // RC7 input
printf("\n\r Testing...");
putc(getc()+1);
I get the "Testing"-part but then it stops. It doesn't echo back. I used an F84 earlier and it started to "work" when I changed from Hyperterminal to TeraTerm.
Since I have an old PCM v.2.686 which doesn't support the F870 I use the 16F873 headerfile (but use F870 in MPLab). Can this be the reason? But comparing the specs and headerfiles it looks like it should work anyway. Everything else I've tried so far has worked, why not this? Any ideas?
Sincerely,
John
___________________________
Original Post ID: 11229
Re: RS232,16F870 problem
PostPosted: Mon Feb 03, 2003 1:23 pm     Reply with quote
:=Hello!
:=I'm having a hard time getting the RS232 PIC/PC communication to work. PIC->PC is ok, but the PIC doesn't seem to read anything on RX even though the signal is there. Checked everything with a scope. I use a MAX232. Tried both hardware UART and software (xmit=b3, rcv=b2) but the same things happen. Tried 4/20Mhz osc with a number of different baudrates but no, it doesn't seem to read RX. Also tried removing fast_io, tris statements, adding PARITY etc but no. Now I'm running out of ideas...
I compiled your program with PCM vs. 2.686, for a 16F877.
I tested it on 16F877 chip and it worked fine.
(I don't have a 16F870).
I then compiled it with PCM vs. 3.136 and briefly compared
the .LST files. I noticed that the older compiler uses the
TRIS instruction, which is supposedly obsolete. This might
be the answer. So let's check that first.
In your program, add the following lines above main():
#byte TRIS_A_REG = 0x85
#byte TRIS_B_REG = 0x86
#byte TRIS_C_REG = 0x87
Then, within main(), comment out your existing tris
statements, and add these lines. Like this:
//set_tris_a ( 0b00000000 );
//set_tris_b ( 0b00000000 );
//set_tris_c ( 0b10000000 );
TRIS_A_REG = 0b00000000;
TRIS_B_REG = 0b00000000;
TRIS_C_REG = 0b10000000;
See if that fixes the problem.
Original Post ID: 11238
John
PostPosted: Mon Feb 03, 2003 4:15 pm     Reply with quote
:=I compiled your program with PCM vs. 2.686, for a 16F877.
:=I tested it on 16F877 chip and it worked fine.
:=(I don't have a 16F870).
:=I then compiled it with PCM vs. 3.136 and briefly compared
:=the .LST files. I noticed that the older compiler uses the
:=TRIS instruction, which is supposedly obsolete. This might
:=be the answer. So let's check that first.
:=In your program, add the following lines above main():
:=#byte TRIS_A_REG = 0x85
:=#byte TRIS_B_REG = 0x86
:=#byte TRIS_C_REG = 0x87
:=Then, within main(), comment out your existing tris
:=statements, and add these lines. Like this:
:=//set_tris_a ( 0b00000000 );
:=//set_tris_b ( 0b00000000 );
:=//set_tris_c ( 0b10000000 );
:=TRIS_A_REG = 0b00000000;
:=TRIS_B_REG = 0b00000000;
:=TRIS_C_REG = 0b10000000;
:=See if that fixes the problem.
Thanks for your suggestion. Tried it, but it didn't make any difference. I checked to see if it responded to any sort of input [if(input(pin_b1)) output_high(pin_c4)] etc. and that seemed fine. I am very lost here...
/John
Original Post ID: 11246
John
I am an idiot...
PostPosted: Mon Feb 03, 2003 4:46 pm     Reply with quote
There are really no excuses but evidently my wife sent some e-mails having my 5 month old son in her lap. At some unattended second he happened to pick out the MAX232 grounding... Why not the supply? That one is bright red?? Why not all wires since he really can't pick anything with any sort of accuracy... Don't know whether I should laugh or cry...
So, I'm really sorry for causing unnecessary work.
/John (maybe I should change my nick?)
Original Post ID: 11248
Re: I am an idiot...
PostPosted: Mon Feb 03, 2003 5:02 pm     Reply with quote
<font face="Courier New" size=-1>:=There are really no excuses but evidently my wife sent some e-mails having my 5 month old son in her lap. At some unattended second he happened to pick out the MAX232 grounding... Why not the supply? That one is bright red?? Why not all wires since he really can't pick anything with any sort of accuracy... Don't know whether I should laugh or cry...
:=So, I'm really sorry for causing unnecessary work.
:=/John (maybe I should change my nick?)
I was about to post (in 30 seconds), that there must
be a hardware problem. :)
One more thing I forgot to mention -- In your #fuses statement
you're using HS, but your crystal is only 4 MHz. The data
sheet recommends using XT mode for that frequency.
</font>
Original Post ID: 11249
