Help me how to config PIC24FJ128GB110 run on 32Mhz
Killer_te
PostPosted: Mon Jul 19, 2010 6:55 am     Reply with quote
Hello
Please tell me how to config PIC24FJ128GB110 run on 32Mhz by CCS C with internal crystal is 8Mhz? and config #fuses? for uart
#include <24FJ128GB110.H>
#include <stdio.h>
#fuses ...?
#use delay (...?)
#use rs232(baud=9600,...)
    printf("HELLO WORLD \n\r");
    printf("TEST");
Thank you very much.
PostPosted: Mon Jul 19, 2010 10:17 am     Reply with quote
You can try below settings. Please consider, that the internal fast RC oscillator isn't crystal accurate. UART baudrates may be critical for extended temperature or power supply range without oscillator calibration. FRC doesn't work for USB in any case.
#fuses FRC_PLL,PLL2
#use delay(clock=32M,internal)
bkamen
PostPosted: Mon Jul 19, 2010 1:10 pm     Reply with quote
#fuses FRC_PLL,PLL2
If he uses #use delay (clock=32M, internal)
He may not need the #fuses FRC_PLL, PLL2
But I would definitely test it -- and then keep an eye.
-- but otherwise, yes. What FvM said.
Cityboy
Re: Help me how to config PIC24FJ128GB110 run on 32Mhz
PostPosted: Wed Jul 21, 2010 7:12 am     Reply with quote
Check this topic https://www.ccsinfo.com/forum/viewtopic.php?t=38529&highlight=dspic33fj256gp710
PostPosted: Wed Jul 21, 2010 8:46 am     Reply with quote
Check this topic
It will mostly cause confusion because dsPIC PLL operation is different from PIC24FJxxGB.
The settings can be basically derived from PIC24 datasheet. The only surprizing point is which #fuse setting will automatically set from #use delay() statement and which won't. Although bkamen's assumption, that the PLL fuses should be automatically set isn't wrong, they actually won't.
bkamen
PostPosted: Wed Jul 21, 2010 11:44 am     Reply with quote
FvM wrote:
Check this topic
But I said to double check it and watch it.
It's worked on some things for me in the past...
But considering all the other issues I have with CCS with code that works today, is to assume it may not tomorrow.
-Ben
PostPosted: Wed Jul 21, 2010 12:55 pm     Reply with quote
Right, I also remember a case, when I was surprised about the "intelligence" of the CCS compiler in setting meaningul #fuse parameters from a #use delay() statement. The problem is however, that there's no documented functionality in this regard, as far as I see.
In the present case, without specifying FRC_PLL, no PLL mode was activated, and then, the PLL divider was set to PLL12 by default, which had to be corrected to PLL2.
bkamen
PostPosted: Wed Jul 21, 2010 12:57 pm     Reply with quote
Blah.
3 cheers for consistency.
-Ben
