#int_ext problem
cchappyboy
#int_ext problem
PostPosted: Tue Jul 20, 2010 3:52 pm     Reply with quote
I use pic16f84a pin6 that is RB0 as ext interrupt.
Part of my program:
int1 ext_status=0;
#int_ext
void extisr()
  ext_status=1;
    ext_status=0;
     ext_int_edge(L to H);
    enable_interrupts(int_ext);
    enable_interrupts(global);
    output_low(pin_a1);
     while(true)
        if(ext_status)
          output_high(pin_a1);
        do somethingelse.......
Actually there is no L to H on the pin6. But every time I give power to the chip the pin_a1 output high. It looks the int_ext interrupt server program has been executed.
I don't know why. Is there something I missed. Please give me a help!!!
PostPosted: Tue Jul 20, 2010 4:06 pm     Reply with quote
Is there a pull-up resistor on that pin, so it's not floating ?
You need a pull-up to hold the pin at a "logic high" level so it
won't trigger on noise. You can use a 4.7K ohm resistor.
Also, clear the interrupt flag before you enable global interrupts.
Add the line shown in bold below:
clear_interrupt(INT_EXT);
cchappyboy
PostPosted: Tue Jul 20, 2010 4:32 pm     Reply with quote
It works after I add clear_interrupt(int_ext);
Thank you so much
PostPosted: Wed Jul 21, 2010 2:24 am     Reply with quote
As an explanation of 'why', look in the data sheet.
Whenever you change the interrupt detection 'edge' (L_TO_H), you can trigger the interrupt. Hence if you want to change this in your code, you should:
1) Ensure interrupts are disabled before changing it (doesn't apply at startup).
2) Change the edge.
3) Clear the interrupt - in case it has triggered.
4) Enable the interrupt
cchappyboy
PostPosted: Thu Jul 22, 2010 10:00 am     Reply with quote
Thank you very much for you response and I have few questions here
what is that mean 'changing it' .
This should be put into interrupt service program?
is that mean i should re_enable it after very interrupt?
where should I enable it.
Thanks again!
