denis_11
UART not work on 18F14k50 |
Posted: Wed Jul 14, 2010 7:13 am |
hello I wrote this simple program to send via UART any text ... why not working?
Code: | #include <18F14K50.h>
#device adc=8
#FUSES HS
#FUSES BORV19
#FUSES NOMCLR //Master Clear pin disabled
#FUSES HFOFST
#FUSES NOWRT0
#FUSES NOWRT1
#FUSES USBDIV1
#FUSES BBSIZ2K //2K words Boot Block size
#FUSES CPUDIV1
#FUSES PLLEN
#FUSES PCLKEN
#use delay(clock=48000000)
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1)
printf("hello");
while(true);
I use a real 12MHz quartz and multiplies it with CPUDIV 48MHz ... I try the firmware with proteus simulation but does not work ... why? everything has always worked ... |
denis_11
Posted: Wed Jul 14, 2010 10:30 am |
What's wrong? nobody knows the solution? I have a problem in the fuses?
I also tried the pic actually mounting the circuit but have not received anything from the UART ... |
Posted: Wed Jul 14, 2010 12:12 pm |
First try it with #use delay() set to 12 MHz, and use the HS fuse.
Disable the PLL. Get it running at 12 MHz initially. |
denis_11
Posted: Wed Jul 14, 2010 12:16 pm |
ok I do the test immediately |
denis_11
Posted: Wed Jul 14, 2010 12:22 pm |
I modified so it does not work the same ... my version of the compiler is 4.106 and I use the PCH16 ...
#device adc=8
#FUSES HS
#FUSES BORV19
#FUSES HFOFST
#FUSES NOWRT0
#FUSES NOWRT1
#FUSES USBDIV1
#FUSES CPUDIV1
//#FUSES PLLEN
#FUSES PCLKEN
#use delay(clock=12000000)
printf("ciao");
while(true);
denis_11
Posted: Wed Jul 14, 2010 12:29 pm |
solved ... I had to change the pins for UART because those pins are used for USB ... thanks!
Posted: Wed Jul 14, 2010 12:30 pm |
I just looked at the data sheet for the 18F14K50. Pins A0 and A1 are
not capable of doing digital output. They can only do input. When
you see the D+ and D- labels on the pins in the data sheet, this should
be a clue that there is something unusual about these pins. In fact,
these are the USB pins. Microchip doesn't allow these pins to ever do
digital output. They can only do input. That's why you can not transmit
data on pin A0. Solution: Choose some different pins.
Look in this section of the data sheet to see the capability of the pins:
Quote: |
TABLE 1-2: PIC18F1XK50/PIC18LF1XK50 PINOUT I/O DESCRIPTIONS |
