When using the SIO program there is a line call ASCII. I can type a line of text to send out the serial port when I click send. Is there any way to append a 'return' char at the end of the line of text.
Posted: Tue Jul 13, 2010 2:48 am
In the 'configuration', 'Set port options'. Enable flow control on transmit only. You can set the 'end of transmit' character (XOFF) to be a carriage return character.
