Counting number of instructions in CCS C
vsmguy
PostPosted: Sat Jul 10, 2010 11:25 am     Reply with quote
I would like to find out, *without* opening the assembly listing, the number of instructions for a line ( or a number of lines ) in CCS C.
Is this possible ( even in conjuction with tools like MPLAB using the plugin )?
For example,
1. I want to find out how many instructions
delay_us(200);
generates
2. I want to find out how many instructions
set_timer1(0);
delay_us(200);
generates
3. Then, I would like to count the number of clock cycles it took to execute each function, *without* opening the assembly listing
PostPosted: Sat Jul 10, 2010 11:55 am     Reply with quote
MPLAB Stopwatch can count instruction cycles.
http://www.ccsinfo.com/forum/viewtopic.php?t=38351
vsmguy
PostPosted: Sat Jul 10, 2010 6:41 pm     Reply with quote
YES!
I remember doing this a long time ago - and it required a little bit of fiddling around - can't seem to find those instructions.
Now, thanks to you - oh great Midrange PIC Programmer, I found them once again :-D
vsmguy
PostPosted: Mon Jul 12, 2010 7:29 pm     Reply with quote
One more question - how do I do the same *but* between two lines in assembly generated by CCS?
For example, say I have written a function called func() that generates the following assembly:
0011: MOVLW 26
0012: MOVWF 04
0013: BCF 03.7
0014: MOVF 00,W
I want to find out how many cycles it takes between lines 11 and 13 - how do I do that?
PostPosted: Mon Jul 12, 2010 8:29 pm     Reply with quote
Look it up in the PIC data sheet. For example, for the 18F452, look in
this section:
TABLE 20-2: PIC18FXXX INSTRUCTION SET
It lists the number of cycles used by each type of instruction.
Just count them off in the .LST file.
vsmguy
PostPosted: Mon Jul 12, 2010 9:56 pm     Reply with quote
this section:
That's what I am doing manually now and it's kinda time consuming for longwinded and involved code ( look at my latest post on delay_us inaccuracy ).
The MPLAB Stopwatch seems to be language independent and and counts the number of ticks.
I was asking if there is anyway I could get it to count ticks by setting breakpoints in the assembly code generated by CCS?
PostPosted: Mon Jul 12, 2010 10:16 pm     Reply with quote
Start exploring MPLAB. Go to the View menu. Bring up the Disassembly
Listing window. Put your breakpoints in there. Explore the program.
Read the Help file.
vsmguy
PostPosted: Mon Jul 12, 2010 10:39 pm     Reply with quote
That's it. Thanks again.
Read the Help file.
I should :'(
