12f675 GP2 has no internal pull-up resistor?
FFT
PostPosted: Thu Jul 08, 2010 7:35 am     Reply with quote
I've enabled internal pull-ups but input(GP2) returns 0...
I initialize the pic using these codes:
#include <12F675.h>
#device adc=10
#FUSES WDT,INTRC_IO,CPD,PROTECT,NOMCLR,PUT,BROWNOUT
#use fast_io(A)
#define GP0   PIN_A0
#define GP1   PIN_A1
#define GP2   PIN_A2
#define GP3   PIN_A3
#define GP4   PIN_A4
#define GP5   PIN_A5
#use delay(clock=4M,RESTART_WDT)
#byte gpio = getenv("SFR:GPIO")
   gpio = 0;
   set_tris_a(0b011111);
   port_a_pullups(TRUE);
   setup_adc_ports(sAN0|sAN1|VSS_VDD);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_wdt(WDT_288MS);
   disable_interrupts(GLOBAL);
   gpio = 0;
And GP2 is not connected anywhere, just blank.
I could not see any note in the datasheet that GP2 has no internal pull-up resistor?
PostPosted: Thu Jul 08, 2010 12:17 pm     Reply with quote
1. Post a complete test program where you actually call this line of code.
The program should be compilable if I copy-and-paste it into MPLAB.
2. Explain how you know that the pin returns 0. The program should
have a short section that does something based on the returned value.
This could be setting an LED on or off, for example.
3. Tell if you're running this test in hardware or in Proteus.
4. Try to make a test program without all that extra code at the start
of main() that is unnecessary (such as disabling peripherals that are
already disabled upon power-on reset of the PIC).
5. Post your compiler version.
FFT
PostPosted: Fri Jul 09, 2010 10:37 am     Reply with quote
I'm testing on a real pcb and the GP2 is blank. My compiler version is 4.107.
in this code below led does not work. If I write GP4 instead of GP2 in if statement, led works (GP4 is already blank). I use GP0-1 as ADC but I removed the adc_read code.
#include <12F675.h>
#device adc=10
#FUSES WDT                      //Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES CPD                      //Data EEPROM Code Protected
#FUSES PROTECT                  //Code protected from reads
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES PUT                      //Power Up Timer
#use fast_io(A)
#define GP0   PIN_A0
#define GP1   PIN_A1
#define GP2   PIN_A2
#define GP3   PIN_A3
#define GP4   PIN_A4
#define GP5   PIN_A5
#bit  Led  = gpio.5
#rom 0x3ff={0x345C} // Calibration Word
   gpio = 0;
   port_a_pullups(TRUE); //*****
   setup_vref(FALSE);
   gpio = 0;
   if(input(GP2) == 1) // returns 0
      Led=1;
//   if(input(GP4) == 1) // returns 1
//      Led=1;
   for(;;)
   delay_us(1);
Thanks in advance.
PostPosted: Fri Jul 09, 2010 11:55 am     Reply with quote
The 12F675 has individual enables for each pin. You have to use a
bitmask as the parameter for the port_a_pullups() function. You can't
use True/False on this PIC. Do it similar to the way you do the TRIS.
FFT
PostPosted: Sat Jul 10, 2010 9:30 am     Reply with quote
It works!!! Smile Thank you very much!
