Problem with function interface spi in CCS
kideltn
PostPosted: Tue Jul 06, 2010 10:38 am     Reply with quote
I'm debugging sdcard interface is to problem with spi function in CCS.
My schematic:(18f4550+sdcard)
I used spi solfware:
#define CS   PIN_D3
#define SCK  PIN_D6
#define SDO  PIN_D5
#define SDI  PIN_D4
#use spi( DI=SDI, DO=SDO, CLK=SCK, BITS=8, stream=sspi)
And the error occurs as above(at the connection between RD5 and D0 has the error:the logic contention)
I thought the pins PORTD was multiplexed so i added
TRISD =0b00100010;//D0 and TXD is input
but still not successful.
Please help me ...!
Thanks a lot !
kideltn
PostPosted: Tue Jul 06, 2010 11:03 am     Reply with quote
My code:
#include "basicsd.h"
#define CS   PIN_D3
#define SCK  PIN_D6
#define SDO  PIN_D5
#define SDI  PIN_D4
#define _DEBUG
#ifdef _DEBUG
#define dbg(str) printf(str)
// Prototypes
void command(int8, int16, int16, int8);
int mmc_init();
// Implementations
// Send 6-byte Command to MMC
void command(int8 cmd, int16 adh, int16 adl, int8 crc)
   spi_xfer(sspi,cmd);
   spi_xfer(sspi,make8(adh,1));
   spi_xfer(sspi,make8(adh,0));
   spi_xfer(sspi,make8(adl,1));
   spi_xfer(sspi,crc);
// Initialize the Card
int mmc_init()
   int16 i;
   // Unselect Card and Send some Dummy Clocks
   output_high(CS);
   for(i= 0; i< 10; i++)
      spi_xfer(sspi,0xEF);
   // Select Card
   output_low(CS);
   // Send Command 0x40: Wake Up the Card
   command(0x40, 0, 0, 0x95);
   for(i= 0; i< 100; i++)
      if(spi_xfer()== 0x01)
   if(i>= 100) // Check for Time-out Error
      return(1);
   dbg("CMD40 OK (R1= 0x01)\n\r");
   // Send Command 0x41: Start Initialize
   command(0x41, 0, 0, 0xFF);
   for(i= 0; i< 1000; i++)
      if(spi_xfer()== 0x00)
   if(i>= 1000) // Check for Time-out Error
      return(1);
   dbg("CMD41 OK (R1= 0x00)\n\r");
   // Return OK
   return 0;
   printf("> MMC Test by DEBUGGER...\n\r");
   printf("> Start MMC Init...\n\r");
   if(mmc_init()== 0)
      printf("> MMC Init Ok...\r\n");
      printf("> failure.continue debug!\r\n");
My above code tested success with pic 16f877a (with the same pins)
PostPosted: Tue Jul 06, 2010 11:46 am     Reply with quote
SPI DO is an output at the processor.
PostPosted: Tue Jul 06, 2010 12:27 pm     Reply with quote
And the other common issues:
- The no pull-up resistors on the DO and DO lines are missing.
- You have not specified the SPI mode in the setup of '#use SPI'. MMC and SD cards can be used in either SPI-mode 0 or 3.
- Your PIC should be running at 3.3V, not 5V (you might be lucky if it works in Proteus, but it will kill real hardware).
- Post your compiler version (the SPI_xfer routines are known to be broken in older v4 compiler versions).
kideltn
PostPosted: Wed Jul 07, 2010 5:34 am     Reply with quote
Thanks every one very much !
I have solved it! (error is confused DO and DI).
