tixmcprods
I2C : multiple read |
Posted: Tue Jul 06, 2010 9:31 am |
I have a problem with my project. The master do some loops and freeze at the second i2c_read (after PIN_A2 turned on).
I tried delay, i2c settings but randomly (from 1 to 27 loops), the master stops.
Here the slave complete .h code :
#include <18F252.h>
#device adc=8
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#use delay(clock=10000000)
#use i2c(Slave,Fast,sda=PIN_C4,scl=PIN_C3,address=0x20)
int state;
int data;
int data1r, data2r;
int data1w = 15;
int data2w = 240;
The slave complete .c code :
#include "main.h"
#ZERO_RAM
#int_SSP
void SSP_isr(void) {
state = i2c_isr_state();
if(state < 0x80) {
data = i2c_read();
switch(state) {
case 1: data1r = data; break;
case 2: data2r = data; break;
else {
state -= 0x80;
switch(state) {
case 0: i2c_write(data1w); break;
case 1: i2c_write(data2w); break;
void main() {
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_SSP);
while(true) {
if(data1r == 'A' && data2r == 'B') output_high(PIN_B0);
else output_low(PIN_B0);
The master complete .h code :
#include <18F2550.h>
#device adc=8
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES PLL1
#FUSES CPUDIV1
#FUSES NOUSBDIV
#FUSES VREGEN //USB voltage regulator enabled
#use i2c(Master,Fast,sda=PIN_B0,scl=PIN_B1)
int data1, data2;
The master complete .c code :
#include "main.h"
#ZERO_RAM
#int_RDA
void RDA_isr(void) {
#int_SSP
void main() {
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
enable_interrupts(INT_RDA);
while(true) {
i2c_start();
i2c_write(0x20);
i2c_write('A');
i2c_write('B');
i2c_stop();
output_high(PIN_A0);
i2c_start();
i2c_write(0x21);
data1 = i2c_read(1);
output_high(PIN_A2);
data2 = i2c_read(0); // RANDOMLY FREEZE HERE !!!
output_low(PIN_A2);
i2c_stop();
if(data1 == 15 && data2 == 240) output_high(PIN_A1);
else output_low(PIN_A1);
output_low(PIN_A0);
Thanks a lot in advance.
TiX |
tixmcprods
Posted: Tue Jul 06, 2010 10:29 am |
Re,
With "SLOW" settings in master and slave, it doesn't freeze anymore.
Both signal and data are OK.
Have you an idea why in "FAST" speed I have that problem ?
Thanks in advance.
TiX |
rnielsen
Posted: Tue Jul 06, 2010 12:07 pm |
Just at a quick glance, I noticed that your master is running at 20MHZ while your slave is running at 10MHZ. I would have them swapped. In my opinion, your slave should be running faster than the master. Odds are, your master, in Fast mode, is sending commands faster than the slave can process them and is probably just barely keeping up until it misses one command and then freezes.
Ronald |
