hollajo
looking for a simple rs232 thing |
Posted: Tue Jul 06, 2010 3:17 am |
Hi every body
Still using my pic18f870 after my problem with ICSP. Now I have another one.
I'd like to write a very simple code to send just the famous HelloWorld on my computer screen via hyper terminal and rs232.
For now I write this
#include <16F870.h>
#include <stdio.h>
#include <stdlib.h>
#use delay (clock=8000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity = N, bits = 8) //XMIT = transmit; RCV = receive
void main ();
void init(void);
void transmit (void);
Fonction principal
init();
do
transmit ();
}while (1);
Fonction initialisation
void init (void)
set_tris_a (0x00); // A5,A4,A3,A2,A1,A0 are outputs
set_tris_b (0x00); // B7,B6,B5,B4,B3,B2,B1,B0 are outputs
set_tris_c (0xC0); // B7,B6 are inputs
// B5,B4,B3,B2,B1,B0 are outputs
Transmit Data
void transmit(void)
printf("Hello World!!"%n);
// while(!kbhit()); // data is transmit into TXREG register
But it doesn't work, my compilation suceed and that's all when i connect my pic via rs 232 it doesn't work.
My wire is connected like this:
Pic PC
2 TX 3 RX
3 RX 2 TX
5 GND 5 GND
Thanks for your help. |
Wayne_
Posted: Tue Jul 06, 2010 4:59 am |
You have no fuse settings?
The init routine is totally pointless in this instance, remove it.
I presume you wanted to output a cr lf. The %n is wrong try:-
printf("Hello World!!\r\n");
You have got an RS232 line driver IC between your PIC and Cable, havn't you? |
jbmiller
Joined: 07 Oct 2006 Posts: 73 Location: Greensville,Ontario
Posted: Tue Jul 06, 2010 5:04 am |
If the PC has a 9 pin Comport, pin 2 is RCV, 3 is XMT and 5 is gnd....
'they' change the standard when 'they' got downsized the 25 pin connectors to the newer 9 pins.Made making cables easier for 'them'.
Easy way to check which is XMT is to put a meter on the pins to GND. Outputs will always show voltage, inputs hang around 0V.
hth
jay |
hollajo
Posted: Tue Jul 06, 2010 5:21 am |
ok i change my wire and i delete the init routine, the fuse is set with the MPLAB in the configuration bits setting
thx for u help ![Smile](images/smiles/icon_smile.gif) |
hollajo
Posted: Tue Jul 06, 2010 6:29 am |
jbmiller wrote: |
I put my metter between pin 3 and 5 and i have -10V is it normal ? and if yes why I have 0 on pin 2 and not +10V ?
How can i be sur that my serial work on my computer ?
edit : i forget something i use a max 233 to make the level conversion between pic and pc |
jbmiller
Posted: Tue Jul 06, 2010 7:34 am |
-10 on pin 3 is normal 'idle' mode for the transmitter section...
0v on pin 2 is normal for the 'idle' mode of the receviver as it is an input
to verify the PC , just jumper pins 2 to 3 on the PC comport. The communications program ( hyperterminal for example) will 'echo' or display whatever you type on the keyboard. |
hollajo
Posted: Tue Jul 06, 2010 7:51 am |
thx so i made the test and the computer reply i still don't know why Hello World don't work.
do you think that is better to write putc into a loop
for example
#define...
void main void
do
putc ("Hello World \n");
delay_ms (5000);
while (1);
Humberto
Posted: Tue Jul 06, 2010 8:19 am |
putc() only send one char. To send a string you need to putc() several times or use printf() which is more adecuate.
In the CCS Compiler Help File Manual you will find all the info of the built in functions.
This code should be enough for this purposse.
#include <16F870.h>
#FUSES NOWDT,HS,PUT,NOPROTECT,NOLVP
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
printf("Hello World");
Did you check your hardware? Check if the 232 level converter generate the appropiate +V and -V voltages.
In the regular ICL232/MAX232 converter type, they are pin2 and pin6 of the transceiver.
Also, try with another terminal emulator. A lot of users of Hiperterminal reported negative comments here.
Humberto |
hollajo
Posted: Tue Jul 06, 2010 8:29 am |
thx I'm going to try tonight and I will reply tomorrow in the morning (french hour ). |
Wayne_
Posted: Tue Jul 06, 2010 9:22 am |
You already have it in a loop
do
transmit ();
}while (1);
Unless you have changed your code.
Even though you have your fuses set in MPLAB you could let us know what they are. I assume you are using either an external 8M crystal or the internal Osc?
Have you tried toggling a pin on the pic every second and measuring it by either putting a LED on it or using a scope or meter to see what it is outputting. Make sure it is not an open collector output.
Try and verify your pic is running.
If you have a scope look at pins C6 and C7. |
hollajo
Posted: Wed Jul 07, 2010 1:34 am |
I use this configuration on MPLAB :
Osc XT (8Mhz) external
WDT OFF
Power up timer OFF
Brown out detect OFF
Low vltage program Enable
Flash Program Enable
Data EE Read OFF
Code Protect OFF
In fact Itest the pin A0 with the led do you think that I must test C6 and C7 ?
If the led bling it's means that the serial com will work ?
I'm going to test now ![Smile](images/smiles/icon_smile.gif) |
Wayne_
Posted: Wed Jul 07, 2010 1:55 am |
So you have an external crystal connected.
Why are you testing pin A0, the code you have shown does not do anything with that pin!
Change your code so it only toggles pin A0 every second. If it does flash then you know your code is running. Then add a putc('A'); and see if it outputs the char A every second. |
hollajo
Posted: Wed Jul 07, 2010 2:40 am |
I was testing A0 just to know if my micro was working
Ok so i just test my soft with one char and if it work i think that i can use the serial comm. |
hollajo
Posted: Wed Jul 07, 2010 3:02 am |
thx for your help i can see the A on my computer screen so if I want send a char series is it better to use printf ('Hello World!!!');
or i must use the pointer with board ? |
hollajo
Posted: Wed Jul 07, 2010 3:09 am |
it work's for hello World.
So now it's a little more complicated.
do you think that is possible to send a frame for example this king of message
0b0111100001
0 to start the com
1 for the bit stop and
the message 11110000 to drive a motor for example or another thing
(ps : i'd like to make a watchwinder that's why i learn all this thing) |
