Fastest/best way to save ext eeprom
pete
PostPosted: Sun Feb 02, 2003 11:24 pm     Reply with quote
I have a problem to save data to external eeprom,ex.every 250 ms.My logger software should calculate time very accurately. I have made inside 1ms clock with timer2 and offen my software work but sometimes my eeprom function didn't write the data.
Should I change inside timer ex. 10ms or 50ms? Or write data different way ?
software:
#INT_TIMER2
void cal() {
counter_ms++;
if(counter_ms==250) save=1;
if(counter_ms==500) save=1;
if(counter_ms==750) save=1;
if(counter_ms==999) save=1;
if(counter_ms>999)
counter_sec++;
counter_ms = 0;
if(counter_sec>255)
{counter_sec = 0;
program....
if(save==1)
disable_interrupts(GLOBAL);
if(fastest==1){
WRITE_EXT_EEPROM(0x05,fast_sec); //sec
WRITE_EXT_EEPROM(0x06,fast_ms_hi); //ms_hi
WRITE_EXT_EEPROM(0x07,fast_ms_lo); //ms_lo
write_ext_eeprom_start(address);
i2c_write(temp_lapCount);
i2c_write(temp_sec);
i2c_write(temp_ms_hi);
i2c_write(temp_ms_lo);
i2c_write(speed);
i2c_stop();
//delay_ms(6);
address+=5;
}}// end if
___________________________
Original Post ID: 11220
Tomi
Re: Fastest/best way to save ext eeprom
PostPosted: Mon Feb 03, 2003 5:46 am     Reply with quote
<font face="Courier New" size=-1>What is your EEPROM type and what is about page boundaries?
E.g. if you use 24LC256 then you have 64-byte boundaries. This means that you must pay attention for your code part:
i2c_write(temp_lapCount); // a page boundary violation could occurs from here
i2c_write(speed); // to here
i2c_stop();
I use something like this:
#separate
void IncPutAddr()
putaddr++;
if (!(putaddr & 0x3F)) { // if the address is at a boudary
TerminateIIC(); // close I2C session
StartIIC(); // and reopen it
WriteIIC(0xA0);
WriteIIC(putaddrH);
WriteIIC(putaddrL);
</font>
Original Post ID: 11225
TSchultz
RE: Fastest/best way to save ext eeprom
PostPosted: Mon Feb 03, 2003 6:47 am     Reply with quote
:=I have a problem to save data to external eeprom,ex.every 250 ms.My logger software should calculate time very accurately. I have made inside 1ms clock with timer2 and offen my software work but sometimes my eeprom function didn't write the data.
:=Should I change inside timer ex. 10ms or 50ms? Or write data different way ?
:=software:
:=#INT_TIMER2
:=void cal() {
:= counter_ms++;
:= if(counter_ms==250) save=1;
:= if(counter_ms==500) save=1;
:= if(counter_ms==750) save=1;
:= if(counter_ms==999) save=1;
:= if(counter_ms>999)
:= counter_sec++;
:= counter_ms = 0;
:= if(counter_sec>255)
:= {counter_sec = 0;
:=program....
:=if(save==1)
:= disable_interrupts(GLOBAL);
:= if(fastest==1){
:= WRITE_EXT_EEPROM(0x05,fast_sec); //sec
:= WRITE_EXT_EEPROM(0x06,fast_ms_hi); //ms_hi
:= WRITE_EXT_EEPROM(0x07,fast_ms_lo); //ms_lo
:= write_ext_eeprom_start(address);
:= i2c_write(temp_lapCount);
:= i2c_write(temp_sec);
:= i2c_write(temp_ms_hi);
:= i2c_write(temp_ms_lo);
:= i2c_write(speed);
:= i2c_stop();
:= enable_interrupts(GLOBAL);
:= //delay_ms(6);
:= address+=5;
:=}}// end if
You may also want to take a look at the FRAM parts from RAMTRON. They are drop-in replacements for the EEPROM but don't have the write delays.
They have one additional drawback in that a read is actually performed as a read and write internally. This means that reading or writing count as a hit against the endurance. This is normally not a problem because they have much higher endurance than EEPROM and their newer, low voltage parts some are listed as having unlimited read/write cycles.
The only change is usually make to the driver is the removal of the write delay.
-Troy
Original Post ID: 11227
Richard Slater
PostPosted: Mon Feb 03, 2003 9:44 am     Reply with quote
:=software:
:=#INT_TIMER2
:=void cal() {
:= counter_ms++;
:= counter_sec++;
:= counter_ms = 0;
:=program....
:=if(save==1)
:= if(fastest==1){
:= i2c_stop();
:= //delay_ms(6);
:= address+=5;
:=}}// end if
You do not show your declarations of the variables 'counter_ms' and 'counter_sec'. If you have declared them as 'int' then this could be part of the problem. They need to be 'long' for the magnitudes you are using.
If they are longs already... please ignore this!
Richard
Original Post ID: 11231
pete
PostPosted: Mon Feb 03, 2003 1:35 pm     Reply with quote
:=<font face="Courier New" size=-1>What is your EEPROM type and what is about page boundaries?
Yes, I use 24LC256 eeprom.
:=E.g. if you use 24LC256 then you have 64-byte boundaries. This means that you must pay attention for your code part:
:=write_ext_eeprom_start(address);
:=i2c_write(temp_lapCount); // a page boundary violation could occurs from here
:=i2c_write(temp_sec);
:=i2c_write(temp_ms_hi);
:=i2c_write(temp_ms_lo);
:=i2c_write(speed); // to here
:=i2c_stop();
:=I use something like this:
:=#separate
:=void IncPutAddr()
:=putaddr++;
:=if (!(putaddr & 0x3F)) { // if the address is at a boudary
:=TerminateIIC(); // close I2C session
:=StartIIC(); // and reopen it
:=WriteIIC(0xA0);
:=WriteIIC(putaddrH);
:=WriteIIC(putaddrL);
:=</font>
Í have list of my data from eeprom. Maybe boudaries could be the problem, I have to try to change my code and tested.
Thanks.
// I started saving data from address 100
0,0:252,0 // lap(int),sec(int):ms(long),rpm(int) ...
0,0:504,0
0,0:751,0
0,1: 3,0
0,1:255,0
0,1:258,238 // first mistake !Should be 1,1:50?,0
0,1:753,0
0,2: 0,0
0,2:252,0
0,2:504,0
0,2:750,0
0,3: 3,0
0,3:254,0
0,3:501,0
0,3:753,0
0,4: 0,0
0,4:251,0
0,4:503,0
0,4:768,3
0,5: 2,0
0,0:252,0
0,0:504,0
0,0:750,0
0,1: 3,0
0,1:255,0
0,1:501,0
0,1:753,0
0,2: 0,0
0,2:252,0
0,2:503,0
0,2:750,0
0,255:535,255 //second one ! 0,3:0,0
0,3:254,0
0,3:500,0
0,3:753,0
0,4: 0,0
0,4:251,0
0,4:503,0
0,4:755,0
0,5: 2,0
0,5:254,0
0,5:500,0
0,5:752,0
0,5:999,0
0,6:255,0
0,6:503,0
0,6:752,0
0,7: 1,0
0,7:257,0
0,7:505,0
0,7:754,0
0,8: 3,0
0,8:251,0
0,8:500,0
0,8:756,0
0,9: 6,0
0,9:254,248 // third one .... and you can see more under
0,9:502,0
0,9:751,0
0,10: 0,0
0,10:256,0
0,10:505,0
0,10:754,0
0,11: 3,0
0,11:252,0
0,11:501,0
0,11:757,0
0,11:999,0
0,12:255,0
0,12:258,244
0,12:753,0
0,13: 3,0
0,13:251,0
0,13:500,0
0,13:757,0
0,13:999,0
0,14:255,0
0,14:503,0
0,14:752,0
0,15: 2,0
0,15:251,0
0,15:507,0
0,15:864,1
0,16: 6,0
0,16:254,0
0,16:503,0
0,16:752,0
0,17: 1,0
0,17:250,0
0,17:506,0
0,17:755,0
0,18: 5,0
0,18:253,0
0,18:502,0
0,18:751,0
0,255:535,255
0,19:257,0
0,19:506,0
0,19:755,0
0,20: 4,0
0,20:253,0
0,20:501,0
0,20:750,0
0,21: 0,0
0,21:256,0
0,21:505,0
0,21:754,0
0,22: 4,0
0,22:252,0
0,22:501,0
0,22:750,0
0,22:999,0
0,23:256,0
0,23:504,0
0,23:753,0
0,24: 3,0
0,24:251,0
0,24:500,0
0,24:757,0
0,24:999,0
0,25:255,250
0,25:504,0
0,25:753,0
0,26: 2,0
0,26:251,0
0,26:507,0
0,26:756,0
0,27: 6,0
0,27:254,0
0,27:503,0
0,27:752,0
0,28: 2,0
0,28:250,0
0,28:258,241
0,28:755,0
0,29: 5,0
0,29:253,0
0,29:502,0
0,29:751,0
0,30: 1,0
0,30:250,0
0,30:506,0
0,30:756,0
0,31: 6,0
0,31:255,0
0,31:504,0
0,31:514,239
0,32: 3,0
0,32:203,0
1,0:250,0
1,0:502,0
1,0:754,0
1,1: 1,0
1,1:252,0
1,1:504,0
1,1:750,0
1,2: 2,0
1,2:254,0
1,2:505,0
1,255:535,255
1,3: 4,0
1,3:255,0
1,3:501,0
1,3:753,0
1,4: 0,0
1,4:251,0
1,4:502,0
1,4:754,0
1,5: 1,0
1,5:253,0
1,5:504,0
1,5:751,0
0,6: 4,0
1,6:250,0
1,6:505,0
1,6:752,0
1,7: 0,0
1,7:254,0
1,7:501,0
1,7:756,0
1,8: 4,0
1,8:251,0
1,8:505,0
1,8:753,0
1,9: 1,255
0,9:255,0
1,9:502,0
1,9:757,0
1,10: 5,0
1,10:252,0
1,10:507,0
1,10:754,0
1,11: 2,0
1,11:257,0
1,11:504,0
1,11:752,0
1,12: 0,0
1,12: 1,247
0,12:502,0
Original Post ID: 11239
pete
PostPosted: Mon Feb 03, 2003 1:39 pm     Reply with quote
:=:=I have a problem to save data to external eeprom,ex.every 250 ms.My logger software should calculate time very accurately. I have made inside 1ms clock with timer2 and offen my software work but sometimes my eeprom function didn't write the data.
:=:=Should I change inside timer ex. 10ms or 50ms? Or write data different way ?
:=:=software:
:=:=#INT_TIMER2
:=:=void cal() {
:=:= counter_ms++;
:=:= if(counter_ms==250) save=1;
:=:= if(counter_ms==500) save=1;
:=:= if(counter_ms==750) save=1;
:=:= if(counter_ms==999) save=1;
:=:= if(counter_ms>999)
:=:= counter_sec++;
:=:= counter_ms = 0;
:=:= if(counter_sec>255)
:=:= {counter_sec = 0;
:=:=program....
:=:=if(save==1)
:=:= disable_interrupts(GLOBAL);
:=:= if(fastest==1){
:=:= WRITE_EXT_EEPROM(0x05,fast_sec); //sec
:=:= WRITE_EXT_EEPROM(0x06,fast_ms_hi); //ms_hi
:=:= WRITE_EXT_EEPROM(0x07,fast_ms_lo); //ms_lo
:=:= write_ext_eeprom_start(address);
:=:= i2c_write(temp_lapCount);
:=:= i2c_write(temp_sec);
:=:= i2c_write(temp_ms_hi);
:=:= i2c_write(temp_ms_lo);
:=:= i2c_write(speed);
:=:= i2c_stop();
:=:= enable_interrupts(GLOBAL);
:=:= //delay_ms(6);
:=:= address+=5;
:=:=}}// end if
:=You do not show your declarations of the variables 'counter_ms' and 'counter_sec'. If you have declared them as 'int' then this could be part of the problem. They need to be 'long' for the magnitudes you are using.
:=If they are longs already... please ignore this!
:=Richard
This is my declarations:
static long counter_ms;
static int counter_sec;
static int counter_kierrokset;
static long wheel_run;
I try before long variables but change to save a little memory.
Thanks,
Pete
Original Post ID: 11240
Richard Slater
PostPosted: Tue Feb 04, 2003 3:40 am     Reply with quote
:=:=:=I have a problem to save data to external eeprom,ex.every 250 ms.My logger software should calculate time very accurately. I have made inside 1ms clock with timer2 and offen my software work but sometimes my eeprom function didn't write the data.
:=:=:=Should I change inside timer ex. 10ms or 50ms? Or write data different way ?
:=:=:=software:
:=:=:=#INT_TIMER2
:=:=:=void cal() {
:=:=:= counter_ms++;
:=:=:= if(counter_ms==250) save=1;
:=:=:= if(counter_ms==500) save=1;
:=:=:= if(counter_ms==750) save=1;
:=:=:= if(counter_ms==999) save=1;
:=:=:= if(counter_ms>999)
:=:=:= counter_sec++;
:=:=:= counter_ms = 0;
:=:=:= if(counter_sec>255)
:=:=:= {counter_sec = 0;
:=:=:=program....
:=:=:=if(save==1)
:=:=:= disable_interrupts(GLOBAL);
:=:=:= if(fastest==1){
:=:=:= WRITE_EXT_EEPROM(0x05,fast_sec); //sec
:=:=:= WRITE_EXT_EEPROM(0x06,fast_ms_hi); //ms_hi
:=:=:= WRITE_EXT_EEPROM(0x07,fast_ms_lo); //ms_lo
:=:=:= write_ext_eeprom_start(address);
:=:=:= i2c_write(temp_lapCount);
:=:=:= i2c_write(temp_sec);
:=:=:= i2c_write(temp_ms_hi);
:=:=:= i2c_write(temp_ms_lo);
:=:=:= i2c_write(speed);
:=:=:= i2c_stop();
:=:=:= enable_interrupts(GLOBAL);
:=:=:= //delay_ms(6);
:=:=:= address+=5;
:=:=:=}}// end if
:=:=You do not show your declarations of the variables 'counter_ms' and 'counter_sec'. If you have declared them as 'int' then this could be part of the problem. They need to be 'long' for the magnitudes you are using.
:=:=If they are longs already... please ignore this!
:=:=Richard
:=This is my declarations:
:=static long counter_ms;
:=static int counter_sec;
:=static int counter_kierrokset;
:=static long wheel_run;
:=I try before long variables but change to save a little memory.
:=Thanks,
:=Pete
Hi there,
If you have already tried longs, then it is a different problem, but if you wish to use the expression
'if(counter_sec >255){...' then you will need to use longs, as 255 is the largest number that can be represented using an eight bit number, and anything larger than that will just wrap around, and introduce bugs.
Sorry this does not help you actual problem, though!
Richard
Original Post ID: 11262
