build error with object files and PIC24FJ64GA002
handixx
PostPosted: Thu Jul 01, 2010 1:43 pm     Reply with quote
hello,
first sorry for my English
I have buy a display from BOlYMIN
http://pdf1.alldatasheet.net/datasheet-pdf/view/316218/BOLYMIN/BEGV627M.html
It is a display embedded system with touch panel and PIC 24fj64. They give the driver for all of item on the board. I have try to compile their demo_prog, but when I build I have this error:
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\Third Party\PICC\Ccsc.exe" +FD "DTP_main.c" +EXPORT I+="C:\Users\stephane\Documents\ELECTRONIQUE\pompe irrigation\Software Utilities\VER101\Demo Test\BOL_lib_627M;C:\Program Files (x86)\PICC\Drivers" +DF +LN +T +A +M -Z +Y=9 +EA
>>> Warning 203 "DTP_main.c" Line 102(1,1): Condition always TRUE
>>> Warning 202 "C:\Users\stephane\Documents\ELECTRONIQUE\pompe irrigation\Software Utilities\VER101\Demo Test\uart.h" Line 18(5,8): Variable never used: rs232_errors
>>> Warning 202 "DTP_main.c" Line 74(13,14): Variable never used: x
>>> Warning 202 "DTP_main.c" Line 74(16,17): Variable never used: y
>>> Warning 202 "DTP_main.c" Line 75(10,16): Variable never used: disp_x
>>> Warning 202 "DTP_main.c" Line 75(18,24): Variable never used: disp_y
C:\Users\stephane\Documents\ELECTRONIQUE\pompe irrigation\Software Utilities\VER101\Demo Test\DTP_main.o ===> 0 Errors, 6 Warnings.
Executing: "C:\Program Files (x86)\Microchip\Third Party\PICC\Ccsc.exe" +FD LINK="BEGV627M_DTP.hex=DTP_main.o,BOL_lib_627M\bklight_pwm.o,BOL_lib_627M\I2c.o,BOL_lib_627M\i2ceeprom.o,BOL_lib_627M\ST7588T.o,BOL_lib_627M\touch.o,BOL_lib_627M\uart.o" +DF +LN +T +A +M -Z +Y=9 +EA
--- Info 300 "BEGV627M_DTP.c" Line 1(0,1): More info: ** Read beyond end of file
*** Error 44 "BEGV627M_DTP.c" Line 1(0,1): Internal Error - Contact CCS
*** "BEGV627M_DTP.c" Line 1: Error #300: More info: ** Read beyond end of file
*** "BEGV627M_DTP.c" Line 1: Error #300: More info: ** Access violation at address 02F69215 in module 'PCD.dll'. Read of address 033CA0F8
1 Errors, 0 Warnings.
Skipping link step. Not all sources built successfully.
BUILD FAILED: Thu Jul 01 21:19:28 2010
I have searched on internet. I have not found the answer. If one guy can help me it will be very nice !! I have buy this items for the fast conception but I have lost 2 days ^^
It is my first time with the 16 bits family and I'm not enjoy ><
Thank you for your answer
best regard
stephane
PostPosted: Thu Jul 01, 2010 3:54 pm     Reply with quote
Is the driver source code compatible with the CCS compiler ?
Do they say it is ? Post a link to it.
handixx
PostPosted: Fri Jul 02, 2010 12:36 am     Reply with quote
the object files was build with CCS.4.093
http://dl.free.fr/mDodKyEgW
this is the link of the driver's packs
PostPosted: Fri Jul 02, 2010 1:06 am     Reply with quote
That website says:
Non-existent file.
handixx
PostPosted: Fri Jul 02, 2010 1:27 am     Reply with quote
http://lamidey.medical.free.fr/Software Utilities.zip
handixx
PostPosted: Fri Jul 02, 2010 1:28 am     Reply with quote
sorry,
http://lamidey.medical.free.fr/driver.zip
PostPosted: Fri Jul 02, 2010 2:05 am     Reply with quote
The file "driver.zip" does not contain any files that have a "main()"
function. I don't see how it can be compiled. It only has .h files
that have function prototypes. There is no actual driver source code.
I am done for the day. Maybe someone else can help.
handixx
PostPosted: Fri Jul 02, 2010 2:58 am     Reply with quote
thank you
this is the object files
this next *.zip is the mplab project demo
http://lamidey.medical.free.fr/Demo_Test.zip
