kaimi
function with return value |
Posted: Thu Jul 01, 2010 1:47 am |
Hi all,
I'm using CCS to compile for PIC16F688. I've met a strange problem with function with return value.
Originally I had this code, which didn't work:
int16 func_A()
int16 my_local_var;
my_local_var = 3000;
return my_local_var;
int16 my_glob_array[8];
void func_B()
int8 i;
for (i=0; i<8; i++)
my_glob_array[i] = func_A();
Not all element in my_glob_array are assigned to 3000, but 28900, -9160.
Isn't that strange?
Has anybody experienced the same thing? I'd very appreciate if someone could give a me a hint where I did wrong? |
sjb
Posted: Thu Jul 01, 2010 6:19 am |
How do you know the array value are wrong?
It does look odd from what you've said, but a simple typo could be the cause (eg. a ';' after the for(;;) statement). So it's often best to post a complete example if you can.
You suspect the return value. Why? (just a hunch, or something else?) |
kaimi
Posted: Thu Jul 01, 2010 7:22 am |
The values (my_glob_array, which are global) are asynchronously sent via serial when requested and I get them displayed in PC.
I think the problem is with the function return value because if I made this (only) change in my code then it's fine:
int16 my_global_var;
void func_A()
int16 my_local_var;
my_global_var = my_local_var;
void func_B()
int8 i;
for (i=0; i<8; i++)
func_A();
my_glob_array[i] = my_global_var;
That is I replaced the use of the return value of the func_A by the use of a global var. Of course the existence of func_A doesn't look to have much sense here, but in my real func_A there's lots code inside before the last assignment to my_local_var. But since the real code failed, I reduced everything for testing down to exactly the same like posted previously, and the output was as posted.
I have one suspicion:
Since my_glob_array is read inside an interrupt (serial RX) and the above code runs in the idle loop, is there possibility that when I have
my_glob_array[i] = func_A() and its execution is interrupted then my_glob_array[i] had some intermediate value instead of the expected?
I've tried disable/enable interrupt around my_glob_array[i] = func_A() too. But that also didn't help. ![Sad](images/smiles/icon_sad.gif) |
Posted: Thu Jul 01, 2010 8:13 am |
What compiler version?.
This is the sort of 'strangeness', that was common with the early 4.xxx releases....
sjb
Posted: Thu Jul 01, 2010 9:27 am |
Well, when does you interrupt routine start firing. If if fires before or while the func_B() then that could easily cause the problem.
A complete example would help. |
Wayne_
Posted: Thu Jul 01, 2010 9:53 am |
the interrupt can't be a problem because you reduced all your code down to what you have posted here!
Quote: | I reduced everything for testing down to exactly the same like posted previously |
and as I see no interrupt it can't be that ;)
Also the code you posted won't run as there is no main routine or fuses etc.
Your problem could be a number of things but until you show me a complete program exhibiting the problem, I am out
[rant]
So many times we have gone through the routine of asking questions to track down a problem based on very little info and without a complete piece of code only to find it was some stupid error somewhere else in the code which either the person with the error finally spotted or they actually, eventually posted something that someone on here could spot! [/rant]
Sorry ![Smile](images/smiles/icon_smile.gif) |
