trouble replacing internal osc with xtal in 18F2620
leporid
PostPosted: Wed Jun 30, 2010 7:34 pm     Reply with quote
I have a board using a PIC18F2620 that has pads for an SMD
crystal. Previously, this board was used without the
crystal and with the internal oscillator. There are no
capacitors with the crystal; I was told that they were
unnecessary if the traces were under half an inch (true?).
I have been unable to make the 18F2620 run at anything
other than 8 mHz, as determined by the the delay_ms test. I
assume that the internal oscillator is taking over due to
some problem with the crystal.
I have tried this with a 16 mHz crystal (with and without
12 pF caps), it produces a 2 ms pulse when delay_ms is 1 ms
and clock=16000000. With a 20 mHz SMD crystal and no caps
the pulse is 2.5 ms instead of 1 ms with clock=20000000.
I have tried many combinations of the fuses listed under
"// CLOCK-related" below, the other lines were kept the
same.
I would like to run the 18F2620 at 20 mHZ with a 20 mHz
crystal. Questions are: 1) are caps required on the crystal
if the leads are very short (~1/4" in this case) 2) What is
the correct #FUSE configuration to run it at 20 mHz with a
20 mHz crystal?
Any help would be much appreciated.
Using CCS C 4.106. Here's my (latest variation of) MAIN.H:
#include <18F2620.h>
#device adc=10
#device PASS_STRINGS=IN_RAM
//#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES BROWNOUT               //brownout reset
//#FUSES BORV21                   //Brownout reset at 2.1V
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
// CLOCK-related
//#FUSES XT                   //XTAL
//#FUSES HS                   //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
//#FUSES FCMEN              //Fail-safe clock monitor
#FUSES PUT                  // Power Up Timer
//#FUSES LPT1OSC              //Timer1 low-power operation
#FUSES NOIESO               //*Internal External Switch Over mode
//#FUSES IESO               //*Internal External Switch Over mode
#use delay(clock=20000000,crystal)
PostPosted: Wed Jun 30, 2010 8:07 pm     Reply with quote
I was told that they were unnecessary if the traces were under half an
inch (true?).
Wrong. You need the capacitors. Two 22 pf caps will work.
crystal.
Use the HS fuse.
I have a board using a PIC18F2620 that has pads for an SMD crystal.
Post a link to the web page for the board.
leporid
PostPosted: Wed Jun 30, 2010 8:19 pm     Reply with quote
Wow, that was a quick reply! Thank you.
The board was designed by someone long gone, it's not
not a publicly available part.
I'll try the higher-value caps and HS alone from the
"clock" related group.
