Two way communication via USB on 18f2455
Rob
PostPosted: Tue Jun 29, 2010 8:05 am     Reply with quote
hi folks,
I am currently writing an application for the 18f2455 device on ccs c. the pic should control an external dds chip from analog, connected via pin a0-02.
I use the following code (based on the compiler included example files)...
//set to 1 to use a PIC with internal USB Peripheral
//set to 0 to use a National USBN960x peripheral
#define __USB_PIC_PERIF__ 1
#include <18F2455.h>
#include "AD9835.c"
  //#define USB_CON_SENSE_PIN PIN_B2   //CCS 18F4550 development kit has optional conection sense pin
//~~~ 16MHZ OSCILLATOR CONFIGS ~~~//
// CPUDIV2 => MCU-Clock = 48 MHz
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL4,CPUDIV2,VREGEN
#use delay(clock=16000000)
// CCS Library dynamic defines.  For dynamic configuration of the CCS Library
// for your application several defines need to be made.  See the comments
// at usb.h for more information
#DEFINE USB_HID_DEVICE     FALSE
#define USB_EP1_TX_ENABLE  USB_ENABLE_BULK  //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_RX_ENABLE  USB_ENABLE_BULK  //turn on EP1 for OUT bulk/interrupt transfers
#define USB_EP1_TX_SIZE    64  //size to allocate for the tx endpoint 1 buffer
#define USB_EP1_RX_SIZE    8   //size to allocate for the rx endpoint 1 buffer
// Include the CCS USB Libraries.  See the comments at the top of these
// files for more information
#include <pic18_usb.h>
#include "usb_desc.h"   //USB Configuration and Device descriptors for this UBS device
#include <usb.c>           //handles usb setup tokens and get descriptor reports
#define SIZE 512
#define CMD_NEW_FREQ 0x01
#define CMD_NEW_FREQ_SET 0x2
#define ACK      0xff
#define READY    0x64
void main( void )
   int8 buf[SIZE];
   unsigned int32 frequency = 0;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   InitialiseDDS();
   usb_init_cs();
   while( TRUE )
      usb_task();
      if(usb_enumerated()) {
         if (usb_kbhit(1)) {
           usb_get_packet(1,buf,8);
           // valid incomming frame?
           // CMD_NEW_FREQ - f1 - f2 -f3 -f4 * ACK
            if ((buf[0] == CMD_NEW_FREQ) && (buf[5] == ACK))
               // freq change
               frequency = 0;
                frequency = buf[1];
                frequency<<=8;
                frequency=frequency|buf[2];
                frequency<<=8;
                frequency=frequency|buf[3];
                frequency<<=8;
                frequency=frequency|buf[4];
                SendFreqRegDDS(ConvertFrequency(frequency));     //convert to register value & send to DDS chip*/
           buf[0]=CMD_NEW_FREQ_SET;
           buf[5]=READY;
           // send ack-frame to the pc
           // CMD_NEW_FREQ_SET - f1 - f2 -f3 -f4 * READY
           usb_puts( 1, buf, SIZE, 100 );
The dds chip should change his frequency (represented by f1-f2-f3-f4) when a valid frame is received. After that, the PIC send an ack-frame to
the PC-Application.
I also used a sniffing tool to observe the bus communication.
The Problem is, that the communication works only on the side from pc to pic. I can't get any data from the PIC back to my application. I have no idea where the problem is. Can somebody see the bug? HELP !!! I really get confused. Twisted Evil
PostPosted: Tue Jun 29, 2010 11:31 am     Reply with quote
if ((buf[0] == CMD_NEW_FREQ) & (buf[5] == ACK))
Change '&' to '&&'
Also change the LVP fuse to NOLVP. Less than 1% of the people on this forum are using the ancient Low Voltage Programmers. With LVP enabled the PIC is susceptible to noise on the LVP input pin.
Post your compiler version number.
Post the release date of your USB.c and pic18_usb.h (see the 'Version History' inside the file).
bungee-
PostPosted: Tue Jun 29, 2010 12:08 pm     Reply with quote
Are you deliberately using USB HID mode? Why don't you use CDC mode?
Rob
PostPosted: Tue Jun 29, 2010 12:37 pm     Reply with quote
Change '&' to '&&'
Yeah thanks a lot! It's not my day today (105°F on the desk and no AC) Crying or Very sad
The compiler version is: 3.222 (yeah really old, i know).
USB.c is: June 20th, 2005
pic18_usb.h is: 06-20-05 Initial Release
PostPosted: Tue Jun 29, 2010 1:26 pm     Reply with quote
I assume you have an external 16 MHz crystal, or 16 MHz oscillator
connected to the PIC's oscillator pin(s).
Your comments imply that you want the PIC's CPU to run at 48 MHz.
But your #use delay() is set for 16 MHz. Furthermore, your fuse setting
of CPUDIV2 will generate a CPU clock of 24 MHz. This must be fixed.
If your real intention is for the CPU clock to be 48 MHz, then you need to
use CPUDIV1, and the #use delay() needs to be set to 48 MHz. Example:
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL4,CPUDIV1,VREGEN
#use delay(clock=48000000)
You can prove this to yourself by running a simple LED blinking test
in hardware. I did this and the following code will blink an LED on pin B0
once per second. This is with a 16 MHz crystal installed on the board.
#include <18F4550.h>
#fuses HSPLL,NOWDT,PUT,BROWNOUT,PLL4, CPUDIV1,NOLVP
  output_high(PIN_B0);
  output_low(PIN_B0);
  delay_ms(900);
Rob
PostPosted: Tue Jun 29, 2010 2:38 pm     Reply with quote
thats right! mea culpa.
use CPUDIV1,
Question Question Question
Why CPUDIV1?
The Primary CLK frequency comes from the 96 MHz PLL and must divided by 2 (CPUDIV2), right?! Also CPUDIV1 is not defined in 18f2455-header file!
PostPosted: Tue Jun 29, 2010 2:46 pm     Reply with quote
It is in vs. 4.109. It has CPUDIV1 to 4.
#device PIC18F2455
#nolist
//////// Program memory: 12288x16  Data RAM: 2048  Stack: 31
//////// I/O: 23   Analog Pins: 13
//////// Data EEPROM: 256
//////// C Scratch area: 00   ID Location: 200000
//////// Fuses: WDT2048,WDT4096,WDT8192,WDT16384,WDT32768,HS,HSPLL,PLL1,PLL2
//////// Fuses: PLL3,PLL4,PLL5,PLL6,PLL10,PLL12,USBDIV,NOUSBDIV,CPUDIV1
//////// Fuses: CPUDIV2,CPUDIV3,CPUDIV4,VREGEN,NOVREGEN
Also note that CCS calls the fuses CPUDIV1 to CPUDIV4. These are
the divisors (1 to 4) for the normal oscillator. The PLL has different
divisors (2 to 6), but you must still use the CPUDV1 to CPUDIV4 fuse
settings. Here is the correspondence:
CPUDIV1 = PLL postscaler divisor of 2.
CPUDIV2 = PLL postscaler divisor of 3.
CPUDIV3 = PLL postscaler divisor of 4.
CPUDIV4 = PLL postscaler divisor of 6.
