klausdejong
CC2420 - IEEE 802.15.4 |
Posted: Sat Jun 26, 2010 2:02 pm |
Is there anyone familiar programming the CC2420 radio in C ??
What I need is a buffered Tx and a buffered Rx.
It must be easy but I'm stuck.
Any help is highly appreciated.
Regards,
Klaus de Jong |
Posted: Sun Jun 27, 2010 12:13 am |
Do you mean interrupt-driven buffers ? Similar to the CCS example
files Ex_Sisr.c and Ex_Stisr.c for the serial port on the PIC ?
I looked with Google and there is sample code out there in C18 and
some other compiler for the cc2420. This code could be translated
to CCS. It may not meet your requirements for buffered code.
Search for cc2420.c with Google to find it. |
klausdejong
Posted: Sun Jun 27, 2010 5:36 am |
Thank you, PCM programmer
The CC2420 has built in support for buffered transmit and receive and it should be not too difficult to implement that.
Actually I'm trying to program the Flexipanel EasyBee which is based on the CC2420.
Any help is welcome at this point.
Thanks and regards,
Klaus de Jong |
klausdejong
Posted: Mon Jun 28, 2010 5:51 am |
Thanks a lot, PCM programmer,
I believe this will help me to get the CC2420/EasyBee started !!!
I let let you know if it works.
Best regards,
Klaus de Jong |
