HELP! Configure Manually IP from ex_stWebserver.c
Rodrigo Rios A de Souza
View user's profile Send private message Send e-mail MSN Messenger ICQ Number
PostPosted: Fri Jun 25, 2010 9:35 am     Reply with quote
I really need some help here.
Hi guys, I´m having some problems when trying to configure manually the IP address of ex_stwebserver.c and ex_st_webserver2.c examples that come with CCS Embedded Ethernet.
It seems that the webserver examples only work with DHCP enabled.
I tried to change the Lines in code Hardware.h manually.
to my IP addresses. Nothing happened.
#define MY_DEFAULT_IP_ADDR_BYTE1 192 //IP ADDRESS
#define MY_DEFAULT_IP_ADDR_BYTE2 168 // This unit's IP address.
#define MY_DEFAULT_IP_ADDR_BYTE3 0
#define MY_DEFAULT_IP_ADDR_BYTE4 15
#define MY_DEFAULT_MASK_BYTE1 255 //NETMASK
#define MY_DEFAULT_MASK_BYTE2 255 // Netmask tells the IP / ARP stack which
#define MY_DEFAULT_MASK_BYTE3 255 // IP's are on your local network.
#define MY_DEFAULT_MASK_BYTE4 0
#define MY_DEFAULT_GATE_BYTE1 192 //GATEWAY IP ADDRESS
#define MY_DEFAULT_GATE_BYTE2 168 // Gateway acts as a conduit between two networks.
#define MY_DEFAULT_GATE_BYTE3 0
#define MY_DEFAULT_GATE_BYTE4 1
and I also changed the ex_webserver2.c file.
#if STACK_USE_MAC
#define STACK_USE_DHCP FALSE //for auto resolution of IP address
#define STACK_USE_ARP TRUE //needed to resolve MAC addresses of IP addresses
#define STACK_USE_UDP TRUE //needed for dhcp and announce
#define STACK_USE_ANNOUNCE TRUE //announce our IP periodically to the network
After these Changes. the LCD output the IP Address of 0.0.0.0 .
And I can´t access the WEbserver.
But If I DEFINE DHCP Enabled in ex_st_Webserver2.c everything comes to normal?
Any Suggestions?
Rodrigo Rios
PostPosted: Fri Jun 25, 2010 12:59 pm     Reply with quote
There are two versions of the hardware.h file in the TCP-IP directory:
c:\program files\picc\tcp-ip\pic examples source\drivers\hardware.h
c:\program files\picc\tcp-ip\pic examples source\tcpip\hardware.h
Are you sure that you changed the correct file ?
Help with Disabling DHCP on ex_st_webserver2
PostPosted: Fri Jun 25, 2010 1:29 pm     Reply with quote
I've changed both. Nothing happened.
Can you help me?
SimpleAsPossible
Maybe something simple?
PostPosted: Wed Jun 30, 2010 7:53 am     Reply with quote
Did you call IPAddrInit() as part of your initialization? I usually have it right before StackInit().
dpechman
PostPosted: Sun Jan 29, 2012 7:06 pm     Reply with quote
once I have initiated my program with STACK_USE_DHCP 1 how can I disable it in runtime?
I want to setup in eeprom a byte to enable/disable DHCP like.
if(read_eeprom(0)){
usingDhcp = 1;
}else{
usingDhcp = 0;
dpechman
PostPosted: Sun Jan 29, 2012 7:44 pm     Reply with quote
seems to work this way to disable DHCP:
smDHCPState = SM_DHCP_DISABLED;
and to enable it again
smDHCPState = SM_DHCP_INIT_FIRST_TIME;
just not sure if it is the right way to do
