Pre-Defined Identifier for compiler version?
andy5056
PostPosted: Fri Jun 25, 2010 8:04 am     Reply with quote
The compiler manual lists several pre-defined pre-processor identifiers like __DATE__ and __TIME__ that can be included in the C source code.
Is there a pre-defined identifier for the compiler version number? If not, is there another to determine the compiler version number automatically?
I am looking for a way to embed the compiler version number in the source code without having to manually update a constant or string value.
Andrew
tesla80
PostPosted: Fri Jun 25, 2010 10:31 am     Reply with quote
Hi, you can use getenv() function for that.
value = getenv (cstring);
VERSION
Returns the compiler version as a float
VERSION_STRING
Returns the compiler version as a string
#IF  getenv("VERSION")<3.050
   #ERROR  Compiler version too old
#ENDIF
andy5056
PostPosted: Thu Jul 01, 2010 10:27 am     Reply with quote
Thanks! That is just what I was looking for.
Andrew
