Problems to address registers and PortF PortG on PIC16F1947
giankaclimb
PostPosted: Wed Jun 23, 2010 3:04 am     Reply with quote
[code assembler]
1093: set_tris_f(0x37);
06D4 3037 MOVLW 0x37
06D5 0021 MOVLB 0x1
06D6 0091 MOVWF 0x11
/* The error is in addressing the registers of PORTG as seen in the example:
where the TRISG register is in memory location 17 (11_hexadecimal) of BANK1 ... this is a abnormal error ------->>>> but must be (as specified by Microchip) in memory location 13 (D_hexadecimal) of Bank6 */
1094: output_bit(PIN_G3,1);
06D7 0022 MOVLB 0x2
06D8 1592 BSF 0x12, 0x3
06D9 0021 MOVLB 0x1
06DA 1192 BCF 0x12, 0x3
where the LATG register is in memory location 17 (11_hexadecimal) of BANK2 ... this is a abnormal error ------->>>> but must be (as specified by Microchip) in memory location 13 (D_hexadecimal) of Bank7 */
HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
giankaclimb
Re: Problems to address registers and PortF PortG on PIC16F1
PostPosted: Wed Jun 23, 2010 3:05 am     Reply with quote
giankaclimb wrote:
[code assembler]
06D5 0021 MOVLB 0x1
06D7 0022 MOVLB 0x2
06D9 0021 MOVLB 0x1
PostPosted: Wed Jun 23, 2010 3:11 am     Reply with quote
What is your compiler version number?
giankaclimb
PostPosted: Wed Jun 23, 2010 3:16 am     Reply with quote
4.109
PostPosted: Wed Jun 23, 2010 2:31 pm     Reply with quote
Vs. 4.109 is buggy for the 16F1947 on Ports F and G. They're using
the wrong register addresses in the compiler database. Also, the .H file
has the wrong pin constants for those ports.
I've posted a program below with some work-around routines.
Here's the .LST file output. It looks correct:
.................... output_bit(PIN_G3, 1);
0018:  MOVLB  06
0019:  BCF    0D.3
001A:  MOVLB  05
001B:  BSF    0D.3
.................... set_TRISF(0x37);
001C:  MOVLW  37
001D:  MOVLB  06
001E:  MOVWF  0C
#include <16F1947.h>
#locate TRISF = 0x30C
#locate TRISG = 0x30D
#define set_TRISF(x)  TRISF = x
#define set_TRISG(x)  TRISG = x
#define PIN_F0  5216
#define PIN_F1  5217
#define PIN_F2  5218
#define PIN_F3  5219
#define PIN_F4  5220
#define PIN_F5  5221
#define PIN_F6  5222
#define PIN_F7  5223
#define PIN_G0  5224
#define PIN_G1  5225
#define PIN_G2  5226
#define PIN_G3  5227
#define PIN_G4  5228
#define PIN_G5  5229
// This macro is a substitute for the CCS output_bit() function.
// It replaces the built-in function.  First it sets the TRIS to
// output for the selected pin.  Then it sets or clears the Port
// pin, based on the 2nd  parameter being 1 or 0.
#define output_bit(pin, value)  {                  \
bit_clear(*(int8 *)((pin >> 3) + 0x80), pin & 7);  \
if(value)                                          \
   bit_set(*(int8 *)(pin >> 3), pin & 7);          \
else                                               \
   bit_clear(*(int8 *)(pin >> 3), pin & 7);        \
set_TRISF(0x37);
giankaclimb
PostPosted: Thu Jun 24, 2010 4:25 am     Reply with quote
Many thanks
PostPosted: Thu Jun 24, 2010 5:20 am     Reply with quote
Did someone report this to CCS so they can fix it?
PostPosted: Thu Jun 24, 2010 1:34 pm     Reply with quote
I reported it just now.
Edited to add an update:
I got an email from CCS support. They say it will be fixed in
the next version, presumably 4.110.
Edited to add:
You requested a substitute for the input() function in a PM.
Here's the macro that I created:
#define input(pin)                                       \
((bit_set(*(int8 *)((pin >> 3) + 0x80), pin & 7) & 0) |  \
(bit_test(*(int8 *)(pin >> 3), pin & 7)))
Last edited by PCM programmer on Fri Jul 02, 2010 12:55 pm; edited 2 times in total
giankaclimb
PostPosted: Fri Jun 25, 2010 12:45 am     Reply with quote
I had already done three days ago, had better tell him more.
Very Happy
Thanks for the Macro to output_bit, I would appreciate if you could pass the Macro for the two input_bit PORT indicated.
Very Happy
