Pic18f4520 Timer1 doesn't work with external clock!
cchappyboy
PostPosted: Tue Jun 22, 2010 4:00 pm     Reply with quote
I used PIC18f4520 and want to make a Real time clock using external clock. That is a 32.768K crystal sit on the pin 15 and pin 16.
The configuration for timer1 is like this
setup_timer_1(t1_external);
set_timer1(0x00);//around 1s
enable_interrupts(int_timer1);
enable_interrupts(global);
but it doesn't work. Because I monitored Timer1 register, use get_timer1(); it always =0.
Then I try another way to use internal clock.
setup_timer_1(t1_internal);
set_timer1(0xbdb);//62.5ms
It works.
Do you know what is the problem when I setup to external clock?
Thanks for your response.
PostPosted: Tue Jun 22, 2010 4:27 pm     Reply with quote
This post shows how to setup Timer1 to use an external 32.768 KHz crystal:
http://www.ccsinfo.com/forum/viewtopic.php?t=25824&start=7
