GLCD on DSPIC PRO 4 problem
jesalf
PostPosted: Sat Jun 19, 2010 4:02 pm     Reply with quote
I have a problem with a graphic lcd connected to a dspic30F6014A. I used a dspic pro 4 board (from mikroe) and ccs compiler v 4.106.
I started with the glcd example and the left side of the glcd it´s ok but the right side has a type of offset. Then I tried a simple program to draw a horizontal line (pixel by pixel) from x=1 y=1 to x=127 y=1, and when the line cross the middle of the glcd it has a jump to y=120.
The same code but for a pic18F4550 works fine in Proteus. Also the same glcd but with MikroC works.
Is the HDM64GS12 driver is compatible with dspic?
Any one have been tried this GLCD with a DSPIC?
Or somebody have a driver for this glcd working with this dspic?
here is my code.
#include <30F6014A.h>
#device ICD=TRUE
#fuses HS,NOWDT,PR
#use delay(clock=10000000)
#define FAST_GLCD
#include <G:\CCS_GLCD_Touchscreen_dsPIC PRO 4\HDM64GS12.c>
#include <G:\CCS_GLCD_Touchscreen_dsPIC PRO 4\graphics.c>
#include <math.h>
int i,j;
   setup_adc_ports(sAN12);
   set_adc_channel(12);
   glcd_init(ON);                               // Must initialize the LCD
   //GLCD_inicializa(1);
   for(j=1;j<=63;j++)
      for(i=1;i<=125;i++)
         GLCD_PIXEL(i,j,1);
         delay_ms(10);
jesalf
PostPosted: Sun Jun 20, 2010 9:27 pm     Reply with quote
in the last post I have a mistake, I wrote "it has a jump to y=120" it should be "it has a jump to y=57" since the glcd is a 128x64 pixels.
Thanks.
PostPosted: Sun Jun 20, 2010 9:58 pm     Reply with quote
One difference between the PCH and the PCD compilers is that the default
data types are different.
The data types used in HDM64GS12.c are:
int1
int8
int16
The PCH manual says:
Note: All types, except float , by default are unsigned; however,
they may be preceded by unsigned or signed.
The PCD manual says:
Note: All types, except char, by default are signed; however,
The fact that PCD variables are 'signed' by default is likely the cause
of your problems.
To fix this, you could:
1. Create a special version of the hdm64gs12.c file, and edit the file
so that all 'int8' and 'int16' declarations are preceded by 'unsigned'.
You could rename the file as hdm64gs12_pcd.c.
or
2. You could experiment with using the #type directive to change the
default behavior of the PCD compiler to be more like PCH. You could
put the following line at the start of the hdm64gs12.c file:
#type unsigned
Then at the end of the file, set it back to normal for PCD:
#type signed
It's possible that graphics.c might have the same problem. Many of the
variable declarations in graphics.c are declared as 'signed' and should
stay that way.
But, there are still a considerable number of plain 'int8' and 'int16'
declarations that will default to 'signed' in PCD when maybe they should
be 'unsigned'.
I don't have the PCD compiler so I can't test any of this. But these are
the areas where I think you need to look.
jesalf
PostPosted: Mon Jun 21, 2010 7:02 pm     Reply with quote
Thanks for the answer,
I took the second option and now it´s working!!
Thank you very much
