Why so many cycles to execute code with dspic30F
buchtsucht
PostPosted: Thu Jun 17, 2010 7:41 am     Reply with quote
I am used to work with PICs like 12Fxx or 18Fxxx and have some rules of thumb, how much time some code needs to execute. As code get more complex, speed of dspic30F drecreases in a terrible way.
Did I have to use special comands to activate the fast DSP-functions of the dsPIC? I can“t read assembler - so maybe somebody can give me a hint.
output_high(PIN_B3);
=> 1 clock cycle ( as expected)
cc=512;
=> 3 clock cycles (expected 1 cycle)
aa+=( (int32)(bb-cc) * (int32)sin8[a] )>>6;
=> 116 clock cycles (much too much! I have expected 10-15 cycles and calculate about 20-25 cycles for the only 8 bit wide 18F252)
// cc=512;
  030E  202004     mov.w #0x200,0x0008
  0310  884064     mov.w 0x0008,0x080c
  0312  EF280E     clr.w 0x080e
// aa+=( (int32)(bb-cc) * (int32)sin8[a] )>>6;
  0318  804044     mov.w 0x0808,0x0008
  031A  804063     mov.w 0x080c,0x0006
  031C  520283     sub.w 0x0008,0x0006,0x000a
  031E  804054     mov.w 0x080a,0x0008
  0320  804073     mov.w 0x080e,0x0006
  0322  5A0303     subb.w 0x0008,0x0006,0x000c
  0324  804000     mov.w 0x0800,0x0000
  0326  020200     call 0x000200
  032A  EF6001     clr.b 0x0001
  032C  200001     mov.w #0x0,0x0002
  032E  780100     mov.w 0x0000,0x0004
  0330  780181     mov.w 0x0002,0x0006
  0332  780005     mov.w 0x000a,0x0000
  0334  780086     mov.w 0x000c,0x0002
  0336  02021C     call 0x00021c
  033A  780280     mov.w 0x0000,0x000a
  033C  780301     mov.w 0x0002,0x000c
  033E  200064     mov.w #0x6,0x0008
  0340  780005     mov.w 0x000a,0x0000
  0342  780086     mov.w 0x000c,0x0002
  0344  E80204     inc.w 0x0008,0x0008
  0346  E90204     dec.w 0x0008,0x0008
  0348  320003     bra z, 0x000350
  034A  D10081     lsr.w 0x0002,0x0002
  034C  D38000     rrc.w 0x0000,0x0000
  034E  37FFFB     bra 0x000346
  0350  B42804     add.w 0x0804
  0352  780001     mov.w 0x0002,0x0000
  0354  B48806     addc.w 0x0806,0x0000
  0356  884030     mov.w 0x0000,0x0806
PostPosted: Thu Jun 17, 2010 3:30 pm     Reply with quote
I'm not too familiar with the dsPIC, but I'd say you have to get your rules of thumb right.
The PIC18 is an 8 bit processor, the dsPIC is 16 bit. Being a 16 bit processor makes the dsPIC faster, but you can only compare the two when using their native bit sizes.
For example a 32-bit multiplication takes 228 cycles on a PIC18f458 and CCS compiler v4.077, not the 20-25 cycles you claim.
The whole expression takes 313 cycles on the PIC18, so the 116 for the dsPIC seem fine to me.
For fastest processing use 16-bit variables, not 32-bit!
The 3 instructions for the assignment I can't explain. Two are expected because you are moving a 32 bit variable on a 16 bit processor. But it seems like there is an unnecessary temp location used.
Again, use 16-bit variables!
What is your compiler version number? Newer versions can be expected to have improved efficiency.
bkamen
PostPosted: Thu Jun 17, 2010 3:42 pm     Reply with quote
BTW,
Reading assembler is simply a matter of getting the datasheet (or in this case, the dataSHEETS that are the dsPIC family reference) and looking up the opcodes in the section that discussed the instruction set.
If you work with micro controllers, it's a good thing (almost invaluable) to be able to read code -- because sometimes library functions don't do what you want.
Might be your code.
Might be the compiler.
With new PIC's, I've helped CCS work out kinks in handling the new device because I've taken the time to learn the instruction set for PIC's.
It's not as hard as you think.
Cheers,
-Ben
bkamen
PostPosted: Thu Jun 17, 2010 3:48 pm     Reply with quote
If you look on PDF page 354 of the dsPIC33F family reference, Table 25-2
You'll see there is no MOV instruction that allows #LIT to F
Only
MOV #LIT -> Wn
MOV Wn -> F
Now, your code shows this for a word (16bits) but I'm assuming you made CC a 32bit long word.
Soooo... if you look at the options, you can't set a 32bit literal.
So you could do
(2) 16bit words and then a double move or
(1) 16bit word, a move including a clear (your case)
(1) 16bit word, a clear, then a double move.
I bet if you change your 'cc=512' to something that uses both words, those instructions would change.
Try it out and see,
Cheers,
-Ben
buchtsucht
PostPosted: Fri Jun 18, 2010 11:05 pm     Reply with quote
Thanks!
With your help, I found the (idiotic) mistake - I have forgotten:
8 Bit PIC => INT= 8Bit
16 Bit Pic => INT= 16 Bit
Additional the CCS compiler for dspic could be better. But playing a little bit with my C-code (having the PIC-functions in mind), I get the expected speed for DSP.
FvM
PostPosted: Sat Jun 19, 2010 2:09 am     Reply with quote
That's completely illusional for 32 bit arithmetics, in both cases.
Based on an analysis of PCD optimization strategy, I would agree. But I wonder what are your criteria in this regard? You confessed not to understand the assembly listing and apparently didn't consider the specific dsPIC architecture properties. How do you know?
A detailed analysis shows, that PCD is actually processing the C code too much "line-by-line", it's reading the code like a abecedarian does in his reading primer. As a result, it is performing many avoidable register and temporary variable loads. I think however, that CCS acted wisely when not trying more optimization, because handling many general purpose registers caused a lot of confusion in previous PCD releases. Some bugs with complex 32-bit expressions have been continued til today...
Another option to achieve faster arithmetic particulary with dSPIC is to utilize the DSP instruction set. But unfortunately PCD can't infer it from C code.
