problem with keypad 4*4
wael_007
PostPosted: Tue Jun 15, 2010 10:45 am     Reply with quote
I have to connect a keypad and LCD with pic 16F877. The simulation of my program is done in ISIS and it works correctly.
But when I do it in reality the LCD works but the keypad no. The pic doesn't wait until I enter a number with keypad. It run as if the keys are always pressed. But if I press reset and from the beginning I press a key in the keypad, the program run normally and then the pic waits until I have to press a key. It makes me crazy because it's running in the invert way. This is my code:
#include <16F877.h>
#include <lcd1.c>
#include<clavier16T.c>
#define Bouton1 PIN_E0       //declaration de bouton 1
#define Bouton2 PIN_E1
#include <math.h>
#include <stdio.h>
char code[5];  //le code deja enregistrer dans eeprom de pic debut de l adresse 0
char code1[5];//le code taper et enregistrer dans eeprom de pic debut de l adresse0x70
char value ;
char str[20];
int32 position1;
byte position01,position02,position03,position04,position05,position06,position07,position08,sens,sens1;
int32 x;
char position[20];
float k;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
  port_b_pullups(true);
   write_eeprom(1,0x30); write_eeprom(2,0x30); write_eeprom(3,0x30); write_eeprom(4,0x30); write_eeprom(5,0x30);
    code[0]=read_eeprom(1);
    code[1]=read_eeprom(2);
    code[2]=read_eeprom(3);
    code[3]=read_eeprom(4);
    code[4]=read_eeprom(5);
   lcd_init();
   kbd_init();
   lcd_gotoxy(1,1);
   lcd_putc("\fbienvenue a valeo...\n");
start:;
   lcd_putc("\fentrez code");
   lcd_putc("\f");
   kbd_init();
  do{
   value=kbd_getc();
   }while(value==0);
   lcd_gotoxy(1,1);
    lcd_putc(0X2A);
   write_eeprom(0X70,value);
   //2d chif of cod
   do
   value=kbd_getc();
   }while(value==0);
    lcd_gotoxy(2,1);
  lcd_putc(0X2A);
   write_eeprom(0X71,value);
   //third chif of cod
     do
   value=kbd_getc();
   }while(value==0);
    lcd_gotoxy(3,1);
   lcd_putc(0X2A);
   write_eeprom(0X72,value);
   //fourth chif of code
        do
   value=kbd_getc();
   }while(value==0);
    lcd_gotoxy(4,1);
  lcd_putc(0X2A);
   write_eeprom(0X73,value);
   //5 chif of code
        do
   value=kbd_getc();
   }while(value==0);
    lcd_gotoxy(5,1);
  lcd_putc(0X2A);
   write_eeprom(0X74,value);
   //copie de code1 dans le RAM
    code1[0]=read_eeprom(0X70);
    code1[1]=read_eeprom(0X71);
    code1[2]=read_eeprom(0X72);
    code1[3]=read_eeprom(0X73);
    code1[4]=read_eeprom(0X74);
   // attend de touche de confirmation qui est le *
    lcd_putc('\f');
   lcd_putc("confirmez par '*'");
   test:;
   value=kbd_getc();
   if (value!=0X2A){goto test;}
   // verification de code
   if (code1[0]!=code[0]){lcd_putc('\f'); lcd_putc("code faux");delay_ms(2000);goto start;}
   if (code1[1]!=code[1]){lcd_putc('\f'); lcd_putc("code faux");delay_ms(2000);goto start;}
   if (code1[2]!=code[2]){lcd_putc('\f'); lcd_putc("code faux");delay_ms(2000);goto start;}
   if (code1[3]!=code[3]){lcd_putc('\f'); lcd_putc("code faux");delay_ms(2000);goto start;}
   if (code1[4]!=code[4]){lcd_putc('\f'); lcd_putc("code faux\f");delay_ms(2000);goto start;}
   if (code1[0]=code[0]){lcd_putc('\f'); lcd_putc("code juste");delay_ms(300);  lcd_putc('\f');}
   if (code1[1]=code[1]){lcd_putc('\f'); lcd_putc("code juste");delay_ms(300);  lcd_putc('\f');}
   if (code1[2]=code[2]){lcd_putc('\f'); lcd_putc("code juste");delay_ms(300);  lcd_putc('\f');}
   if (code1[3]=code[3]){lcd_putc('\f'); lcd_putc("code juste");delay_ms(300);  lcd_putc('\f');}
   if (code1[4]=code[4]){lcd_putc('\f'); lcd_putc("code juste");delay_ms(300);  lcd_putc('\f');}
   lcd_putc("entrer position");
// lcd_gotoxy(1,2);
 //x=input(PIN_C0);
  //rintf(str, "%09lu",x);
 //rintf(lcd_putc,"%d",x);
// (input(bouton1) ==0 || input(bouton2)==0)
position:;
position01=input(PIN_C0);
position02=input(PIN_C3);
position03=input(PIN_C4);
position04=input(PIN_C5);
position05=input(PIN_C6);
position06=input(PIN_C7);
position07=input(PIN_A0);
position08=input(PIN_A1);
position1=(position01*1+position02*2+position03*4+position04*8+position05*16+position06*32+position07*64+position08*128);
//position1= position1*32;
lcd_gotoxy(1,2);
do
if (input(Bouton1) ==0) {printf(lcd_putc,"+%u",position1);output_high(PIN_C1);goto position;}
if (input(Bouton2) ==0) {printf(lcd_putc,"-%u",position1);output_high(PIN_C2);goto position;}
}while(input(Bouton1==0)&& input(Bouton2==0));
PostPosted: Tue Jun 15, 2010 11:19 am     Reply with quote
Remove about 90% of your code, and just work on the keypad problem.
Get the keypad working reliably, then put back in the rest of your code.
wael_007
PostPosted: Tue Jun 15, 2010 11:28 am     Reply with quote
i did it with a just the lcd and keypad parts of my code
but it doesn t work
PostPosted: Tue Jun 15, 2010 11:39 am     Reply with quote
Try using the keypad and lcd drivers in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=40369
