switch or if/else if
Goto page 1, 2  Next
P51D
PostPosted: Tue Jun 08, 2010 10:10 am     Reply with quote
Hello all
I've some problems with the speed of a little program.
What optimization-level does the CCS PCWHD 4.104 have? because the loop-speed of the main-functions seems like the great switch is programmed like a if{}else if{} statement.
and these part of the C/ASM-list file says the same:
....................    switch (RS232_state){
00C0C:  PUSH    23C2
00C0E:  MOV     [--W15],W0
00C10:  LSR     W0,#8,W0
00C12:  CLR.B   1
00C14:  XOR     #0,W0
00C16:  BRA     Z,C32
00C18:  XOR     #1,W0
00C1A:  BRA     Z,CA4
00C1C:  XOR     #3,W0
00C1E:  BRA     Z,CE0
00C20:  XOR     #1,W0
00C22:  BRA     Z,DE2
00C24:  XOR     #7,W0
00C26:  BRA     Z,E36
00C28:  XOR     #1,W0
00C2A:  BRA     Z,F86
00C2C:  XOR     #3,W0
00C2E:  BRA     Z,FA2
00C30:  BRA     FC8
....................       case waitENQ:
....................          switch (rxBuf[index_rxBuf_R]){
00C32:  MOV     235A,W0
00C34:  SE      W0,W0
00C36:  MOV     #235C,W4
00C38:  ADD     W0,W4,W5
00C3A:  MOV.B   [W5],W0L
00C3C:  CLR.B   1
00C3E:  XOR     #3F,W0
00C40:  BRA     Z,C48
00C42:  XOR     #3A,W0
00C44:  BRA     Z,C6C
00C46:  BRA     C88
....................             case '?':                                       // Suche der LCU
....................                printf(txBuf_Write,"USB LCU");
00C48:  MOV     #0,W1
00C4A:  MOV     W1,W0
00C4C:  CALL    974
00C50:  INC     W1,W1
00C52:  MOV     W1,[W15++]
00C54:  PUSH    243E
00C56:  MOV.B   W0L,[W15-#1]
00C58:  POP     243E
00C5A:  CALL    B66
00C5E:  MOV     [--W15],W1
00C60:  MOV     #6,W0
00C62:  CPSGT   W1,W0
00C64:  BRA     C4A
....................                output_high(LED_green);
00C66:  BSET.B  2D1.5
....................                break;
00C68:  GOTO    CA0
....................             case ENQ:
....................                RS232_state = waitSOH;                       // In nächsten State wechselnd
00C6C:  MOV     23C2,W0
00C6E:  SWAP    W0
00C70:  MOV.B   #1,W0L
00C72:  SWAP    W0
00C74:  MOV     W0,23C2
....................                txBuf_Write(ACK);
00C76:  MOV     243E,W0
00C78:  SWAP    W0
00C7A:  MOV.B   #6,W0L
00C7C:  SWAP    W0
00C7E:  MOV     W0,243E
00C80:  CALL    B66
00C84:  GOTO    CA0
....................             default:
....................                txBuf_Write(rxBuf[index_rxBuf_R]);           // Unbekanter Befehl zurückgeben
00C88:  MOV     235A,W0
00C8A:  SE      W0,W0
00C8C:  MOV     #235C,W4
00C8E:  ADD     W0,W4,W0
00C90:  MOV.B   [W0],W5L
00C92:  PUSH    243E
00C94:  MOV.B   W5L,[W15-#1]
00C96:  POP     243E
00C98:  CALL    B66
00C9C:  GOTO    CA0
There are only goto's at the breaks.
How could I set the optimization-level higher, so that I received a jump-table for switch statements?
Or isn't this possible with the ccs-compilers?
I use the PCWHD for a dsPIC30F6012A.
Thank you for helping
best wishes
P51D
PostPosted: Tue Jun 08, 2010 11:23 am     Reply with quote
See these threads on switch-case efficiency in CCS:
http://www.ccsinfo.com/forum/viewtopic.php?t=28643
http://www.ccsinfo.com/forum/viewtopic.php?t=21373
http://www.ccsinfo.com/forum/viewtopic.php?t=17868
http://www.ccsinfo.com/forum/viewtopic.php?t=20721
P51D
PostPosted: Tue Jun 08, 2010 12:15 pm     Reply with quote
Thank you for the ansver.
Why doesn't the ccs compiler create any jump-table if there is a default-case?
best wishes
P51D
PostPosted: Tue Jun 08, 2010 12:19 pm     Reply with quote
Email CCS support and ask them. (This forum consists of compiler users).
P51D
PostPosted: Wed Jun 09, 2010 1:19 am     Reply with quote
How could I do it, if I need one?
I use the switch for a communication protocol and there it is necessary to have some default-actions.
and what happened when I uses switchs in some cases like this?
switch(rxByte){
   case 0:
   case 1:
   case 2:
      switch(cmd){
         case 0:
         case 1:
thank you for helping
best wishes
P51D
SherpaDoug
PostPosted: Wed Jun 09, 2010 6:39 am     Reply with quote
Write a test program and look at the list file. That is the best way to see how the compiler will handle the situation.
P51D
PostPosted: Wed Jun 09, 2010 12:45 pm     Reply with quote
ok, I've did it:
.................... switch(a){
00A6C:  PUSH    2430
00A6E:  MOV     [--W15],W0
00A70:  LSR     W0,#8,W0
00A72:  CLR.B   1
00A74:  XOR     #0,W0
00A76:  BRA     Z,A82
00A78:  XOR     #1,W0
00A7A:  BRA     Z,A88
00A7C:  XOR     #3,W0
00A7E:  BRA     Z,A8E
00A80:  BRA     AB6
....................    case 0:
....................       output_high(LED_red);
00A82:  BSET.B  2D1.6
00A84:  GOTO    AB6
....................    case 1:
00A88:  BSET.B  2D1.6
00A8A:  GOTO    AB6
....................    case 2:
....................       switch(b){
00A8E:  MOV     2432,W0
00A90:  CLR.B   1
00A92:  XOR     #0,W0
00A94:  BRA     Z,AA0
00A96:  XOR     #1,W0
00A98:  BRA     Z,AA6
00A9A:  XOR     #3,W0
00A9C:  BRA     Z,AAC
00A9E:  BRA     AB2
00AA0:  BSET.B  2D1.6
00AA2:  GOTO    AB2
00AA6:  BSET.B  2D1.6
00AA8:  GOTO    AB2
00AAC:  BSET.B  2D1.6
00AAE:  GOTO    AB2
00AB2:  GOTO    AB6
hmmm....
first, there is no difference between the switch with a default-case. I can't also see something like a jump-table at the beginning of the switch.
I will testing these different versions with an oszi, but I think, that CCS could not create so fast code... because the only gotos are the breaks.
Did I do something wrong, or is there no fast-switch version possible?
Thank for answering
best wishes
P51D
PostPosted: Wed Jun 09, 2010 1:19 pm     Reply with quote
Read Ttelmah's comments in this post about how the number of
cases also affects the generation of a Jump Table:
http://www.ccsinfo.com/forum/viewtopic.php?t=20721&start=4
It's not just the existence of a Default case. It is also the number
of cases.
P51D
PostPosted: Wed Jun 09, 2010 1:56 pm     Reply with quote
Switch with 10 cases, and in one case is also a switch with 10 other cases:
No change.
The first list-file part
switch(a){
00A70:  PUSH    2430
00A72:  MOV     [--W15],W0
00A74:  LSR     W0,#8,W0
00A76:  CLR.B   1
00A78:  XOR     #0,W0
00A7A:  BRA     Z,AA6
00A7C:  XOR     #1,W0
00A7E:  BRA     Z,AAC
00A80:  XOR     #3,W0
00A82:  BRA     Z,AB2
00A84:  XOR     #1,W0
00A86:  BRA     Z,AB8
00A88:  XOR     #7,W0
00A8A:  BRA     Z,ABE
00A8C:  XOR     #1,W0
00A8E:  BRA     Z,AC4
00A90:  XOR     #3,W0
00A92:  BRA     Z,ACA
00A94:  XOR     #1,W0
00A96:  BRA     Z,AD0
00A98:  XOR     #F,W0
00A9A:  BRA     Z,AD6
00A9C:  XOR     #1,W0
00A9E:  BRA     Z,ADC
00AA0:  XOR     #3,W0
00AA2:  BRA     Z,AE2
00AA4:  BRA     AE8
00AA6:  BSET.B  2D1.6
00AA8:  GOTO    AE8
The communication switch is build like this:
#define  waitENQ              0
#define  waitSOH              1
#define  waitCMD              2
#define  waitNUM              3
#define  waitPAR              4
   #define  waitRED              0
   #define  waitGREEN            1
   #define  waitBLUE             2
   #define  waitAX1              3
   #define  waitAX2              4
   #define  waitAX3              5
#define  waitACK              5
#define  waitEOT              6
There is a main-switch with 6 cases and in case 4 there is another switch with 5 cases.
In the linked post is something written about more than 5 cases...
the dummy switch says the opposite.
When I read this, I think the ccs compiler has the same optimization like the standard versions...
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en534868
best wishes
P51D
P51D
PostPosted: Sun Jun 13, 2010 7:36 am     Reply with quote
OK, now I've tested more different versions of switch with the result, that all switchs are made with if else if.
There is no performance upgrade if there is no default case and the cases are in line (from 0 to 50).
The loop-time is various (tested with toggle a pin) and the cases had all the same action.
Is there any possibility like the gcc to create manual a jump-table?
Something like this:
static void *jumptable[] = { &&case1, &&case2, &&case3 };
goto *jumptable[i];
case1:
    goto end_switch;
case2:
    goto end_switch;
case3:
    goto end_switch;
end_switch:
P51D
PostPosted: Sun Jun 13, 2010 10:03 am     Reply with quote
You need to tell us more, and show a real example doing this.
I have just tried a simple example, doing 'garbage', with 4.104:
#include <18F452.h>
#fuses XT
#use rs232(baud=300,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
   int8 tval;
   int8 sval;
   for (sval=0;sval<10;sval++) {
      switch (sval) {
      case 0:
         tval=1;
      case 2:
         tval*=2;
      case 3:
         tval-=1;
      case 4:
         tval+=1;
      case 5:
         tval=4;
      case 6:
         tval/=2;
      case 7:
         tval=6;
      case 8:
         tval=0;
      case 9:
         tval=2;
      printf("%u/n/r",tval);
   while (TRUE);
and it happily develops a jump table for you.
0144:  ADDWF  FE8,W
0146:  CLRF   FF7
0148:  RLCF   FF7,F
014A:  ADDLW  5F
014C:  MOVWF  FF6
014E:  MOVLW  01
0150:  ADDWFC FF7,F
0152:  TBLRD*-
0154:  MOVF   FF5,W
0156:  MOVWF  FFA
0158:  TBLRD*
015A:  MOVF   FF5,W
015C:  MOVWF  FF9
015E:  DATA EC,00
0160:  DATA 20,01
0162:  DATA F2,00
0164:  DATA F8,00
0166:  DATA FE,00
0168:  DATA 04,01
016A:  DATA 0A,01
016C:  DATA 10,01
016E:  DATA 16,01
0170:  DATA 1A,01
You need to remove the 'nolist' option from the processor header, or the table _will not_ be visible. All you see for the 'switch', is the code to call the table:
....................       switch (sval) {
00E0:  MOVF   07,W
00E2:  ADDLW  F6
00E4:  BC    0120
00E6:  ADDLW  0A
00E8:  GOTO   0144
Adding 'default', still switches to not using a table.
P51D
PostPosted: Sun Jun 13, 2010 10:18 am     Reply with quote
This is my test-switch:
the c-file:
for(i=0;i<10;i++){
   switch(i){
      case 0:
         output_toggle(LED_red);
      case 1:
         output_toggle(LED_blue);
      case 2:
         output_toggle(LED_green);
      case 3:
         output_toggle(LED_orange);
      case 4:
      case 5:
      case 6:
      case 7:
      case 8:
         printf(txBuf_Write,"hello");
      case 9:
         printf(txBuf_Write,"world");
C/ASM-List file:
.................... for(i=0;i<10;i++){
003A4:  MOV     23C4,W0
003A6:  CLR.B   1
003A8:  MOV     W0,23C4
003AA:  MOV     23C4,W0
003AC:  LSR     W0,#8,W0
003AE:  CP.B    W0L,#A
003B0:  BRA     GE,468
....................    switch(i){
003B2:  PUSH    23C4
003B4:  MOV     [--W15],W0
003B6:  LSR     W0,#8,W0
003B8:  CLR.B   1
003BA:  XOR     #0,W0
003BC:  BRA     Z,3E4
003BE:  XOR     #1,W0
003C0:  BRA     Z,3EA
003C2:  XOR     #3,W0
003C4:  BRA     Z,3F0
003C6:  XOR     #1,W0
003C8:  BRA     Z,3F6
003CA:  XOR     #7,W0
003CC:  BRA     Z,3FC
003CE:  XOR     #1,W0
003D0:  BRA     Z,402
003D2:  XOR     #3,W0
003D4:  BRA     Z,408
003D6:  XOR     #1,W0
003D8:  BRA     Z,40E
003DA:  XOR     #F,W0
003DC:  BRA     Z,414
003DE:  XOR     #1,W0
003E0:  BRA     Z,436
003E2:  BRA     458
....................          output_toggle(LED_red);
003E4:  BTG.B   2D1.6
003E6:  GOTO    458
....................          output_toggle(LED_blue);
003EA:  BTG.B   2D0.1
003EC:  GOTO    458
....................          output_toggle(LED_green);
003F0:  BTG.B   2D1.5
003F2:  GOTO    458
....................       case 3:
....................          output_toggle(LED_orange);
003F6:  BTG.B   2D0.2
003F8:  GOTO    458
....................       case 4:
003FC:  BTG.B   2D1.6
003FE:  GOTO    458
....................       case 5:
00402:  BTG.B   2D0.1
00404:  GOTO    458
....................       case 6:
00408:  BTG.B   2D1.5
0040A:  GOTO    458
....................       case 7:
0040E:  BTG.B   2D0.2
00410:  GOTO    458
....................       case 8:
....................          printf(txBuf_Write,"hello");
00414:  MOV     #0,W1
00416:  MOV     W1,W0
00418:  CALL    100
0041C:  INC     W1,W1
0041E:  MOV     W1,[W15++]
00420:  PUSH    23C6
00422:  MOV.B   W0L,[W15-#1]
00424:  POP     23C6
00426:  CALL    26A
0042A:  MOV     [--W15],W1
0042C:  MOV     #4,W0
0042E:  CPSGT   W1,W0
00430:  BRA     416
00432:  GOTO    458
....................       case 9:
....................          printf(txBuf_Write,"world");
00436:  MOV     #0,W1
00438:  MOV     W1,W0
0043A:  CALL    112
0043E:  INC     W1,W1
00440:  MOV     W1,[W15++]
00442:  PUSH    23C6
00444:  MOV.B   W0L,[W15-#1]
00446:  POP     23C6
00448:  CALL    26A
0044C:  MOV     [--W15],W1
0044E:  MOV     #4,W0
00450:  CPSGT   W1,W0
00452:  BRA     438
00454:  GOTO    458
00458:  MOV     23C4,W0
0045A:  LSR     W0,#8,W0
0045C:  INC.B   W0L,W0L
0045E:  PUSH    23C4
00460:  MOV.B   W0L,[W15-#1]
00462:  POP     23C4
00464:  GOTO    3AA
?? Where is this option? as a fuse?
best wishes
P51D
PostPosted: Sun Jun 13, 2010 2:21 pm     Reply with quote
At the top of each header file, there is a line '#nolist'. This turns _off_ listing in the assembler .lst file, for some of the internal code.
On your example, the code is so short in each case, that the individual 'test' option, actually (just) results in shorter code than the jump table. The optimiser seems to be being 'smart ' enough to decide this, and is opting to do the individual tests.
P51D
PostPosted: Mon Jun 14, 2010 1:12 am     Reply with quote
Now I've tried it with your example and also with another one where in the cases were more code (printf).
The jump-table was nowhere created:
00466:  PUSH    23C6
00468:  MOV     [--W15],W0
0046A:  LSR     W0,#8,W0
0046C:  CLR.B   1
0046E:  XOR     #0,W0
00470:  BRA     Z,494
00472:  XOR     #2,W0
00474:  BRA     Z,49E
00476:  XOR     #1,W0
00478:  BRA     Z,4B2
0047A:  XOR     #7,W0
0047C:  BRA     Z,4C2
0047E:  XOR     #1,W0
00480:  BRA     Z,4D2
00482:  XOR     #3,W0
00484:  BRA     Z,4DC
00486:  XOR     #1,W0
00488:  BRA     Z,4F4
0048A:  XOR     #F,W0
0048C:  BRA     Z,4FE
0048E:  XOR     #1,W0
00490:  BRA     Z,508
00492:  BRA     512
I have changed the header-file like this:
//////// Standard Header file for the DSPIC30F6012A device ////////////////
#device DSPIC30F6012A
//#nolist
//////// Program memory: 49152x24  Data RAM: 8192  Stack: 31
//////// I/O: 52   Analog Pins: 16
//////// Data EEPROM: 4096
//////// Fuses: XTL,HS,XT,XT_PLL4,XT_PLL8,XT_PLL16,ER_IO,ER,EC,EC_IO,EC_PLL4
//////// Fuses: EC_PLL8,EC_PLL16,LP,FRC,LPRC,PR,NOCKSFSM,CKSNOFSM,CKSFSM,WDT
//////// Fuses: NOWDT,WPSB1,WPSB2,WPSB3,WPSB4,WPSB5,WPSB6,WPSB7,WPSB8,WPSB9
//////// Fuses: WPSB10,WPSB11,WPSB12,WPSB13,WPSB14,WPSB15,WPSB16,WPSA1,WPSA8
//////// Fuses: WPSA64,WPSA512,NOPUT,PUT4,PUT16,PUT64,BROWNOUT,NOBROWNOUT
//////// Fuses: BORRES,BORV27,BORV42,LPOL_LOW,HPOL_LOW,NOPWMPIN,MCLR,NOMCLR
//////// Fuses: PROTECT,NOPROTECT,WRT,NOWRT,DEBUG,NODEBUG,COE,NOCOE,ICSP1
//////// Fuses: ICSP2,ICSP3,ICSP4,FRC_PLL4,FRC_PLL8,FRC_PLL16,HS2_PLL4
//////// Fuses: HS2_PLL8,HS2_PLL16,HS3_PLL4,HS3_PLL8,HS3_PLL16,PR_PLL,BORV45
//////// Fuses: NOWRTSS,WRTSS,NOSSS,SSSS8K,SSSS16K,SSSS32K,NOSSS,SSSH8K
//////// Fuses: SSSH16K,SSSH32K,NORSS,RSS256,RSS2048,RSS4096,WRTB,NOWRTB
//////// Fuses: NOBSS,BSSSS,BSSSM,BSSSL,NOBSS,BSSHS,BSSHM,BSSHL,NOEBS,EBS
//////// Fuses: NORBS,RBSS,RBSM,RBSL,NOESS,ESSS,ESSM,ESSL,PROTECT_HIGH
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
//                         SET_PULLUP(), INPUT(),
//                         OUTPUT_LOW(), OUTPUT_HIGH(),
//                         OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
This is the result with your controller:
....................    int8 tval;
....................    int8 sval;
....................    for (sval=0;sval<10;sval++) {
00E0:  CLRF   06
00E2:  MOVF   06,W
00E4:  SUBLW  09
00E6:  BNC   0144
00E8:  MOVF   06,W
00EA:  ADDLW  F6
00EC:  BC    0128
00EE:  ADDLW  0A
00F0:  GOTO   0148
....................          tval=1;
00F4:  MOVLW  01
00F6:  MOVWF  05
00F8:  BRA    0128
....................          tval*=2;
00FA:  BCF    FD8.0
00FC:  RLCF   05,F
00FE:  BRA    0128
....................          tval-=1;
0100:  MOVLW  01
0102:  SUBWF  05,F
0104:  BRA    0128
....................          tval+=1;
0106:  MOVLW  01
0108:  ADDWF  05,F
010A:  BRA    0128
....................          tval=4;
010C:  MOVLW  04
010E:  MOVWF  05
0110:  BRA    0128
....................          tval/=2;
0112:  BCF    FD8.0
0114:  RRCF   05,F
0116:  BRA    0128
....................          tval=6;
0118:  MOVLW  06
011A:  MOVWF  05
011C:  BRA    0128
....................          tval=0;
011E:  CLRF   05
0120:  BRA    0128
....................          tval=2;
0122:  MOVLW  02
0124:  MOVWF  05
0126:  BRA    0128
....................       printf("%u/n/r",tval);
0128:  MOVFF  05,07
012C:  MOVLW  1B
012E:  MOVWF  08
0130:  BRA    0034
0132:  MOVLW  06
0134:  MOVWF  FF6
0136:  MOVLW  00
0138:  MOVWF  FF7
013A:  MOVLW  04
013C:  MOVWF  07
013E:  BRA    00A2
0140:  INCF   06,F
0142:  BRA    00E2
....................    while (TRUE);
0144:  BRA    0144
0146:  SLEEP
Is there one more setting?
best wishes
P51D
PostPosted: Mon Jun 14, 2010 7:30 am     Reply with quote
In your second lot of code, you have the jump table.
The GOTO 0148 instruction at 0xF0, is jumping to the jump table code. You need to then look at the code at 0148, which is the code to load a value from the table, and jump to it.
In your first lot of code, the test and branch version, is faster and smaller, for all except the last two solutions, than the jump table solution. It takes 'best case' 5 instruction times, and 'worst case', 21 instruction times. Average 13 instruction times. The jump table solution takes 18 instruction times for every possible value. The optimiser is deciding that the test is faster, since it is...
Goto page 1, 2  Next
Page 1 of 2
