Pointer Problem
DonWare
Pointer Problem
PostPosted: Tue Jun 08, 2010 10:00 am     Reply with quote
I'm not sure this is related to my other problem I've been posting about
but I'm having a problem using a pointer. I was wondering if somebody could look at this code and see what might be wrong with it. The second comment describes the problem. Thanks.
void main(){
       int8   rx_buff[22];
       rx_buff[3]=0x36;
       called_routine(&rx_buff[3]);       //  I do need [3] here
void called_routine(int8 *string_start){
    int8   cc;
    cc=&(*string_start++);   // cc = 6 at this point, not 0x36
mkuang
Re: Pointer Problem
PostPosted: Tue Jun 08, 2010 11:20 am     Reply with quote
void main(){
       int8   rx_buff[22];
       rx_buff[3]=0x36;
    int8   cc;
So you passed the address of rx_buffer[3] to call_routine(). Now *string_start = 0x36, and *string_start++ = 0x37. cc is still just the address of rx_buffer[3]. What do you think is wrong ?
DonWare
PostPosted: Tue Jun 08, 2010 11:34 am     Reply with quote
OK I figured it out.
It should be: cc=*string_start++;
Thanks.
sjb
Re: Pointer Problem
PostPosted: Wed Jun 09, 2010 1:58 am     Reply with quote
mkuang wrote:
...Now *string_start = 0x36, and *string_start++ = 0x37. cc is still just the address of rx_buffer[3]. What do you think is wrong ?
NO! Just to avoid this little bit of dis-information confusing other people with pointer problems I think this need comment. The first part is correct, *string_start results in 0x36, but *string_start++ is still 0x36. The ++ operator increments string_start after the value is obtained for the *string_start part of the expression, it does not increment the 0x36 value. It's the same thing as writing...
cc = *string_start;  // get the value pointed at by string_start
string_start++;      // increments string_start
Note that string_start is an address, a pointer to a int8. Both the * and ++ operators work on the address but operator precedence means * works before ++
mkuang
Re: Pointer Problem
PostPosted: Wed Jun 09, 2010 7:15 am     Reply with quote
You are right. I stand corrected.
