PCD: Trouble with RTOS
Goto page 1, 2  Next
babos
PostPosted: Sun Jun 06, 2010 11:15 am     Reply with quote
I'm new from CCS compiler and from SourceBoost C++(rtos).
Now I 've make some test like this :
#include <33FJ256GP710.h>
#DEVICE ADC=10
#fuses HS,PR_PLL    // Crystal HS, 4xPLL
#fuses NOIESO       // No 2-speed Start Up
#fuses NOJTAG       // No JTAG
#fuses NOPROTECT    // No Memory Protection
#fuses NOWDT        // No WatchDog Timer
#fuses NODEBUG      // Debug Mode.
#use delay(clock=40M, oscillator=8M)
#use rs232(UART2, STREAM=serial_debug, baud=9600, bits=8)
#include "lcd_ex16.c"
#include "init_timer1.c"
#include "isr_rtc.c"
#include "init_ADC.c"
unsigned char seconds = 0;      #locate seconds = 0x900
unsigned char minutes = 0;      #locate minutes = 0x902
unsigned char hours = 0;       #locate hours   = 0x904
unsigned int adc_value = 0;       #locate adc_value = 0x906
int1 toggle_led = 0;
#int_timer1 level=4
void isr(void)
   // RTC interrupt handler
   toggle_led ^= 0x01;
   if(toggle_led)
      output_high(PIN_A0);
      output_low(PIN_A0);
   isr_rtc();               // refresh LCD RTC time
   set_timer1(0x8000);
   // main program
   Init_Timer1();
   init_ADC();
   lcd_init();
   home_clr();
   printf(lcd_puts,"\fRTC 00:00.00");
   printf(lcd_puts,"\nADC 0.00 ");
   output_float(PIN_A0);
   //loop
      adc_value = read_adc();
      lcd_gotoxy(5,2);
      printf(lcd_puts,"%3.2f v.",adc_volts(adc_value));
Omit any other files , this work fine without problem.
If i try to use rtos in this mode :
#DEVICE ADC=10
#use delay(clock=32M, oscillator=8M)
#use rtos(timer=0,minor_cycle=100ms)
#task(rate=100ms,max=100ms)
void task1();
#int_timer1 level=4
void isr(void)
   toggle_led ^= 0x01;
   if(toggle_led)
      output_low(PIN_A0);
   isr_rtc();
   set_timer1(0x8000);
void task1()
      lcd_gotoxy(5,2);
   // main program
   Init_Timer1();
   init_ADC();
   lcd_init();
   home_clr();
   rtos_run();
   //loop
The debugger (I maybe) have a stack overflow or other and stop it resetting CPU.
What's wrong?
Thanks for your help.
Babos
Shocked Confused
PostPosted: Sun Jun 06, 2010 1:25 pm     Reply with quote
What's your compiler version ? According to this thread, there were
problems with the RTOS in the PCD compiler, in mid-August 2009.
This would be around version 4.096 of the compiler.
http://www.ccsinfo.com/forum/viewtopic.php?t=39677
I don't have the PCD compiler, so I can't give any more help than this.
babos
PostPosted: Sun Jun 06, 2010 1:28 pm     Reply with quote
CCS C Compiler version 4.1.0.8 PCD is the current that I use.
Best regards.
Idea
PostPosted: Sun Jun 06, 2010 2:05 pm     Reply with quote
You should check what's the exact reset cause. Stack overflow doesn't sound unlikely, because PCD has a (too) low default stack assignment. Stack overflows have been reported e.g. with float arithmetic. You may want to try with an increased stack size.
babos
PostPosted: Sun Jun 06, 2010 3:30 pm     Reply with quote
Is the same with this sample code !!!!
#DEVICE ADC=10
#use rs232(UART1, STREAM=serial_debug, baud=9600, bits=8)
#use rtos(timer=0, minor_cycle=100ms)
#task(rate=1000ms, max=100ms)
void first_task()
   printf("task 1\n\r");
#task(rate=500ms,max=100ms)
void second_task()
   printf("task 2\n\r");
void third_task()
   printf("task 3\n\r");
// MAIN
   rtos_run();
there would have to put any switch (?) in a linker compiler setting before use RTOS????
Confused
PostPosted: Sun Jun 06, 2010 11:25 pm     Reply with quote
You can try, if increasing the stack changes anything
#build(stack = 256)
But there may be other reset causes (e.g. address error trap) as well. Because all exceptions are unhandled by default, you won't see but a trap conflict in the reset register. You need to install respective trap interrupts to identify specific execptions.
babos
PostPosted: Mon Jun 07, 2010 12:36 am     Reply with quote
Nothing to do. Please see me how trap interrupts in previous sample code.Thank's.
I use :
Explorer16 demo board with Mplab 8.50 + ICD2
this is the build result:
Executing: "C:\Program files\Picc\CCSC.exe" +FD "rtos_1.c" +DF +LN +T +A +M -Z +ICD +Y=9 +EA      Memory usage:   ROM=1%      RAM=1% - 1%      0 Errors,  0 Warnings.Loaded E:\nanoGel\firmware\rtos_1\rtos_1.cof.BUILD SUCCEEDED: Mon Jun 07 08:27:45 2010
This, the disassembly listing :
---  C:\PROGRA~1\PICC\devices\33FJ256GP710.h  ----------------------------------------------------
1:                 //////// Standard Header file for the DSPIC33FJ256GP710 device ////////////////
2:                 #device DSPIC33FJ256GP710
 00200  EF2032     clr.w 0x0032
 00202  2020C3     mov.w #0x20c,0x0006
 00204  418000     add.w 0x0006,0x0000,0x0000
 00206  BA4010     tblrdl.b [0x0000],0x0000
 00208  EF6001     clr.b 0x0001
 0020A  060000     return
 0020C  006174     nop
 0020E  006B73     nop
 00210  003120     nop
 00212  000D0A     nop
 00214  000000     nop
 00216  EF2032     clr.w 0x0032
 00218  202223     mov.w #0x222,0x0006
 0021A  418000     add.w 0x0006,0x0000,0x0000
 0021C  BA4010     tblrdl.b [0x0000],0x0000
 0021E  EF6001     clr.b 0x0001
 00220  060000     return
 00222  006174     nop
 00224  006B73     nop
 00226  003220     nop
 00228  000D0A     nop
 0022A  000000     nop
 0022C  EF2032     clr.w 0x0032
 0022E  202383     mov.w #0x238,0x0006
 00230  418000     add.w 0x0006,0x0000,0x0000
 00232  BA4010     tblrdl.b [0x0000],0x0000
 00234  EF6001     clr.b 0x0001
 00236  060000     return
 00238  006174     nop
 0023A  006B73     nop
 0023C  003320     nop
 0023E  000D0A     nop
 00240  000000     nop
 00242  EF2032     clr.w 0x0032
 00244  2024E3     mov.w #0x24e,0x0006
 00246  418000     add.w 0x0006,0x0000,0x0000
 00248  BA4010     tblrdl.b [0x0000],0x0000
 0024A  EF6001     clr.b 0x0001
 0024C  060000     return
 0024E  00085C     nop
 00250  000864     nop
 00252  00086C     nop
---  E:\nanoGel\firmware\rtos_1\rtos_1.c  --------------------------------------------------------
1:                 #include <33FJ256GP710.h>
 00000  0402D2     goto 0x0002d2
2:
3:                 #DEVICE ADC=10
4:                 #fuses HS,PR_PLL    // Crystal HS, 4xPLL
5:                 #fuses NOIESO       // No 2-speed Start Up
6:                 #fuses NOJTAG       // No JTAG
7:                 #fuses NOPROTECT    // No Memory Protection
8:                 #fuses NOWDT        // No WatchDog Timer
9:                 #fuses NODEBUG      // Debug Mode.
10:
11:
12:
13:                #use delay(clock=40M, oscillator=8M)
14:
15:
16:                #use rs232(UART1, STREAM=serial_debug, baud=9600, bits=8)
17:
18:                #build(stack=256)
19:
20:                #use rtos(timer=0, minor_cycle=100ms)
21:
22:
23:                #task(rate=1000ms, max=100ms)
24:                void first_task()
25:                {
26:                   printf("task 1\n\r");
 00254  200001     mov.w #0x0,0x0002
 00256  780001     mov.w 0x0002,0x0000
 00258  020200     call 0x000200
 0025C  E80081     inc.w 0x0002,0x0002
 0025E  781F81     mov.w 0x0002,[0x001e++]
 00260  AF2223     btsc.b 0x0223,#1
 00262  37FFFE     bra 0x000260
 00264  881120     mov.w 0x0000,0x0224
 00266  7800CF     mov.w [--0x001e],0x0002
 00268  200070     mov.w #0x7,0x0000
 0026A  E60800     cpsgt.w 0x0002,0x0000
 0026C  37FFF4     bra 0x000256
27:                }
 0026E  202540     mov.w #0x254,0x0000
 00270  B7E861     mov.b 0x0000,0x0861
 00272  000000     nop
 00274  B7E862     mov.b 0x0000,0x0862
 00276  200000     mov.w #0x0,0x0000
 00278  B7E863     mov.b 0x0000,0x0863
 0027A  04039A     goto 0x00039a
28:
29:                #task(rate=500ms,max=100ms)
30:                void second_task()
31:                {
32:                   printf("task 2\n\r");
 0027E  200001     mov.w #0x0,0x0002
 00280  780001     mov.w 0x0002,0x0000
 00282  020216     call 0x000216
 00286  E80081     inc.w 0x0002,0x0002
 00288  781F81     mov.w 0x0002,[0x001e++]
 0028A  AF2223     btsc.b 0x0223,#1
 0028C  37FFFE     bra 0x00028a
 0028E  881120     mov.w 0x0000,0x0224
 00290  7800CF     mov.w [--0x001e],0x0002
 00292  200070     mov.w #0x7,0x0000
 00294  E60800     cpsgt.w 0x0002,0x0000
 00296  37FFF4     bra 0x000280
33:                }
 00298  2027E0     mov.w #0x27e,0x0000
 0029A  B7E869     mov.b 0x0000,0x0869
 0029C  000000     nop
 0029E  B7E86A     mov.b 0x0000,0x086a
 002A0  200000     mov.w #0x0,0x0000
 002A2  B7E86B     mov.b 0x0000,0x086b
 002A4  04039A     goto 0x00039a
34:
35:                #task(rate=100ms,max=100ms)
36:                void third_task()
37:                {
38:                   printf("task 3\n\r");
 002A8  200001     mov.w #0x0,0x0002
 002AA  780001     mov.w 0x0002,0x0000
 002AC  02022C     call 0x00022c
 002B0  E80081     inc.w 0x0002,0x0002
 002B2  781F81     mov.w 0x0002,[0x001e++]
 002B4  AF2223     btsc.b 0x0223,#1
 002B6  37FFFE     bra 0x0002b4
 002B8  881120     mov.w 0x0000,0x0224
 002BA  7800CF     mov.w [--0x001e],0x0002
 002BC  200070     mov.w #0x7,0x0000
 002BE  E60800     cpsgt.w 0x0002,0x0000
 002C0  37FFF4     bra 0x0002aa
39:                }
 002C2  202A80     mov.w #0x2a8,0x0000
 002C4  B7E871     mov.b 0x0000,0x0871
 002C6  000000     nop
 002C8  B7E872     mov.b 0x0000,0x0872
 002CA  200000     mov.w #0x0,0x0000
 002CC  B7E873     mov.b 0x0000,0x0873
 002CE  04039A     goto 0x00039a
40:
41:                // MAIN
42:                void main()
43:                {
 002D2  A8E081     bset.b 0x0081,#7
 002D4  EF2744     clr.w 0x0744
 002D6  200124     mov.w #0x12,0x0008
 002D8  883A34     mov.w 0x0008,0x0746
 002DA  280004     mov.w #0x8000,0x0008
 002DC  881104     mov.w 0x0008,0x0220
 002DE  204004     mov.w #0x400,0x0008
 002E0  881114     mov.w 0x0008,0x0222
 002E2  200814     mov.w #0x81,0x0008
 002E4  881144     mov.w 0x0008,0x0228
 002E6  EFA32C     setm.w 0x032c
 002E8  EFA32A     setm.w 0x032a
 002EA  EFA36C     setm.w 0x036c
 002EC  EFA36A     setm.w 0x036a
 002EE  27700F     mov.w #0x7700,0x001e
 002F0  277FF0     mov.w #0x77ff,0x0000
 002F2  B7A020     mov.w 0x0000,0x0020
 002F4  000000     nop
44:                   rtos_run();
 002F6  EF685C     clr.b 0x085c
 002F8  2000A4     mov.w #0xa,0x0008
 002FA  8842E4     mov.w 0x0008,0x085c
 002FC  200014     mov.w #0x1,0x0008
 002FE  8842F4     mov.w 0x0008,0x085e
 00300  202540     mov.w #0x254,0x0000
 00302  B7E861     mov.b 0x0000,0x0861
 00304  000000     nop
 00306  B7E862     mov.b 0x0000,0x0862
 00308  200000     mov.w #0x0,0x0000
 0030A  B7E863     mov.b 0x0000,0x0863
 0030C  EF6864     clr.b 0x0864
 0030E  200054     mov.w #0x5,0x0008
 00310  884324     mov.w 0x0008,0x0864
 00312  EF2867     clr.w 0x0867
 00314  2027E0     mov.w #0x27e,0x0000
 00316  B7E869     mov.b 0x0000,0x0869
 00318  000000     nop
 0031A  B7E86A     mov.b 0x0000,0x086a
 0031C  200000     mov.w #0x0,0x0000
 0031E  B7E86B     mov.b 0x0000,0x086b
 00320  EF686C     clr.b 0x086c
 00322  200014     mov.w #0x1,0x0008
 00324  884364     mov.w 0x0008,0x086c
 00326  EF286F     clr.w 0x086f
 00328  202A80     mov.w #0x2a8,0x0000
 0032A  B7E871     mov.b 0x0000,0x0871
 0032C  000000     nop
 0032E  B7E872     mov.b 0x0000,0x0872
 00330  200000     mov.w #0x0,0x0000
 00332  B7E873     mov.b 0x0000,0x0873
 00334  EF685A     clr.b 0x085a
 00336  EF2000     clr.w 0x0000
 00338  2FFFF0     mov.w #0xffff,0x0000
 0033A  2A0100     mov.w #0xa010,0x0000
 0033C  217B80     mov.w #0x17b8,0x0000
 0033E  218B80     mov.w #0x18b8,0x0000
 00340  A90080     bclr.b 0x0080,#0
 00342  8042D1     mov.w 0x085a,0x0002
 00344  DD08C1     sl 0x0002,#1,0x0002
 00346  020242     call 0x000242
 0034A  784100     mov.b 0x0000,0x0004
 0034C  40C0E1     add.b 0x0002,#1,0x0002
 0034E  784001     mov.b 0x0002,0x0000
 00350  B7E000     mov.b 0x0000,0x0000
 00352  020242     call 0x000242
 00356  B7E001     mov.b 0x0000,0x0001
 00358  780302     mov.w 0x0004,0x000c
 0035A  784116     mov.b [0x000c],0x0004
 0035C  7840D6     mov.b [++0x000c],0x0002
 0035E  784056     mov.b [++0x000c],0x0000
 00360  B7E003     mov.b 0x0000,0x0003
 00362  E80306     inc.w 0x000c,0x000c
 00364  E80B16     inc.w [0x000c],[0x000c]
 00366  784016     mov.b [0x000c],0x0000
 00368  B7E001     mov.b 0x0000,0x0001
 0036A  AE2042     btss.b 0x0042,#1
 0036C  370003     bra 0x000374
 0036E  E80306     inc.w 0x000c,0x000c
 00370  E80B16     inc.w [0x000c],[0x000c]
 00372  E90306     dec.w 0x000c,0x000c
 00374  E80306     inc.w 0x000c,0x000c
 00376  784016     mov.b [0x000c],0x0000
 00378  B54003     sub.b 0x0003,0x0000
 0037A  AE2042     btss.b 0x0042,#1
 0037C  37000E     bra 0x00039a
 0037E  784001     mov.b 0x0002,0x0000
 00380  B54001     sub.b 0x0001,0x0000
 00382  AE2042     btss.b 0x0042,#1
 00384  37000A     bra 0x00039a
 00386  E90306     dec.w 0x000c,0x000c
 00388  E90306     dec.w 0x000c,0x000c
 0038A  EB1B00     clr.w [0x000c++]
 0038C  EB1B00     clr.w [0x000c++]
 0038E  AFE004     btsc.b 0x0004,#7
 00390  370004     bra 0x00039a
 00392  E80306     inc.w 0x000c,0x000c
 00394  781FB6     mov.w [0x000c++],[0x001e++]
 00396  781FB6     mov.w [0x000c++],[0x001e++]
 00398  060000     return
 0039A  EC685A     inc.b 0x085a
 0039C  B3C033     mov.b #0x3,0x0006
 0039E  B5485A     sub.b 0x085a,0x0000
 003A0  AE2042     btss.b 0x0042,#1
 003A2  37FFCF     bra 0x000342
 003A4  EF685A     clr.b 0x085a
 003A6  AF0080     btsc.b 0x0080,#0
 003A8  37FFC9     bra 0x00033c
 003AA  37FFFD     bra 0x0003a6
 003AC  EFE85A     setm.b 0x085a
 003AE  37FFFF     bra 0x0003ae
The source code is in the compiler manual. I do not know what to do.
Sad Sad Sad Sad
babos
PostPosted: Tue Jun 08, 2010 4:11 pm     Reply with quote
Dear CCS Official Support,
have you any solution for my problem?
Please is urgent to know any answer.
I've buy $600.00 PCWHD IDE Compiler + another Year subsciption for upgrade ($375).
What I must do ??????????
sorry for languages.
best regards
Rolling Eyes Rolling Eyes Rolling Eyes
dyeatman
PostPosted: Tue Jun 08, 2010 9:41 pm     Reply with quote
This is NOT CCS Support!!!! This just a USER Forum.
Please read the notes at the top right of this web page.
Send support questions to CCS using the email provided above...
Google and Forum Search are some of your best tools!!!!
babos
PostPosted: Wed Jun 09, 2010 1:13 am     Reply with quote
Sorry... but I'm very demoralized. CCS does not respond to my requests and on the internet I only found the same problem with other people but no solution .... I Try in every way.
Thanks again if anyone can help me. Would it be possible to use a different RTOS with CCS? And if so, what would be the best?
Idea Idea Idea
marius
PostPosted: Wed Jun 09, 2010 9:21 am     Reply with quote
I have the same problem on a PIC24f.
When the program try to execute rtos_run(); there are reset.
The restart_cause() is 15 which means RESTART_TRAP_CONFLICT.
I wrote one month ago to ccs support they said :
We have some one running some tests now on the PIC24 RTOS to find out
if there are any outstanding issues. Check back next week.
And nothing . I use PCD 4.107 version.
babos
PostPosted: Sat Jun 12, 2010 2:35 am     Reply with quote
We just have to wait ???
Do you know if it works RTOS 18F series processors?
If I let you know news. The same you do, thanks Marius.
Question
PostPosted: Sat Jun 12, 2010 7:55 am     Reply with quote
Yes, that can be expected in case of an unhandled address error or stack overflow. It would be important to know which one of both has occured. I previously suggested to increase the stack as a first measure. Did you try?
For further reading, refer to the below threads:
http://www.ccsinfo.com/forum/viewtopic.php?t=36479
http://www.ccsinfo.com/forum/viewtopic.php?t=40083
Address error trap can be caused by bad pointer operations in user code, but mostly indicates a PCD bug, according to my experience. There have been various cases with previous PCD releases, and I expect some trapdoors still to remain.
babos
PostPosted: Sat Jun 12, 2010 7:59 am     Reply with quote
Ok FvM,
waiting do some testing.
marius
PostPosted: Mon Jun 14, 2010 2:04 am     Reply with quote
Question
Yes CCS RTOS works on PIC18f ( 18f4523 for my application )
It was very easy to use. It was my 1st application with CCS RTOS.
best regards
Marius
Goto page 1, 2  Next
Page 1 of 2
