18f452 modbus problem
ali
PostPosted: Tue Jun 08, 2010 2:04 am     Reply with quote
#include <stdio.h>
#include <stdlib.h>
#define MODBUS_BUS SERIAL
#define MODBUS_SERIAL_RX_BUFFER_SIZE 64
#define MODBUS_SERIAL_INT_SOURCE MODBUS_INT_EXT
#define MODBUS_TYPE MODBUS_TYPE_MASTER
#define MODBUS_SERIAL_RX_PIN PIN_B0
#define MODBUS_SERIAL_TX_PIN PIN_B1
#define MODBUS_SERIAL_BAUD 19200
#define MODBUS_SLAVE_ADDRESS 10
#include "modbus.c"
char full_message[10]={'$','R','F','Z','Z','E','N','D',0xD,0xA};
int16 temp;
int8 lsb,msb;
int8 tempson1,tempson2;
int i;
void read_all_holding()
   if(!(modbus_read_holding_registers(MODBUS_SLAVE_ADDRESS,1024,8)))
      //Started at 1 since 0 is quantity of coils//
      for(i=1; i < (modbus_rx.len); ++i)
        fprintf(COM_A,"%X ", modbus_rx.data[i]);
       fprintf(COM_A,"Exception %X", modbus_rx.error);
   modbus_read_holding_registers(MODBUS_SLAVE_ADDRESS,1030,2);
   setup_wdt(WDT_ON);
 //  setup_timer_0(RTCC_INTERNAL);
  // enable_interrupts(INT_EXT);
   //SET_TRIS_B( 0xf0 );
   modbus_init();
   tempson1=0xD;
   tempson2=0xA;
   fprintf(COM_A,"$C2");
  read_all_holding();
   output_low(PIN_B4);
   //fprintf(COM_A,full_message);
  // fprintf(COM_A,full_message);
   delay_ms(400);
   //fprintf(COM_A,"denemebilgisayarı");
    output_high(PIN_B4);
    //delay_ms(1000);
This is my hardware test program. I was compiling and only one warning message:
Interrupt disabled during call to prevent re-entrancy:(modbus_calc_crc)
I send to read holding register command. My second uart to pc send me only time out error. But if I can use 232 serial monitor I can see all correct register value.
mkuang
PostPosted: Tue Jun 08, 2010 7:18 am     Reply with quote
Since you did not post the modbus_calc_crc routine it is hard for us to say what is going on.
Linuxbuilders
PostPosted: Sat Mar 03, 2012 6:27 pm     Reply with quote
inside modbus.c line 729
replace modbus_calc_crc(c);
with following:
         #if (MODBUS_SERIAL_TYPE == MODBUS_ASCII)
            modbus_serial_lrc+=c;
         #else
            unsigned int8 uIndex ; // will index into CRC lookup table
            uIndex = (modbus_serial_crc.b[1]) ^ c; // calculate the CRC
            modbus_serial_crc.b[1] = (modbus_serial_crc.b[0]) ^ modbus_auchCRCHi[uIndex];
            modbus_serial_crc.b[0] = modbus_auchCRCLo[uIndex];
         #endif
Help "d" others and then you shell receive some help from "d" others.
