18F2450 running slow
Jody
PostPosted: Mon Jun 07, 2010 5:00 am     Reply with quote
I am using the 18F2450 with the internal oscillator...
And when I toggle an output in it runs very slow.
I think I have mashed something up with the oscillator settings but have no idea what......
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_oscillator(OSC_INTRC);
      delay_ms(1);
   output_high(PIN_C0);
   delay_ms(1);
   output_low(PIN_C0);
Header file:
#include <18F2450.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC                    //Internal RC Osc
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV20                   //Brownout reset at 4.3V
#FUSES NOPUT                      //Power Up Timer
#FUSES NOVREGEN                 //USB voltage regulator disabled
#FUSES NOSTVREN                   //Stack full/underflow will cause reset
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOLPT1OSC                  //Timer1 configured for low-power operation
#use delay(clock= 8000000)
Anybody an idea??
PIC is running a factor of 500 too slow.....
Regards,
Jody
PostPosted: Mon Jun 07, 2010 10:41 am     Reply with quote
Try a more simple program that blinks an LED once per second.
If it doesn't work, then post your compiler version, Vdd voltage for the
PIC, and post if you have all the required external connections such as
the MCLR pull-up resistor. Also post if you are testing this in hardware
or in Proteus.
#fuses INTRC_IO,NOWDT,PUT,NOBROWNOUT,NOLVP
    output_low(PIN_C0);
mskala
PostPosted: Mon Jun 07, 2010 11:28 am     Reply with quote
on this device is going to be the 31K oscillator, I believe. So telling the
code that clock is 8000000 will be a problem.
Jody
PostPosted: Mon Jun 07, 2010 12:46 pm     Reply with quote
mmmh I think that Mskala is right...
I will connect a oscillator to the pic to check if I can get it working any faster....
Thanks for the assistance,
I will let you know
Regards,
Jody
Jody
connec a 8MHz crystal
PostPosted: Tue Jun 08, 2010 2:28 am     Reply with quote
And still it is running slow.....
Anybody an idea??
Changed the fuse setting to HS for the crystal...
Regards,
Jody
mkuang
PostPosted: Tue Jun 08, 2010 7:10 am     Reply with quote
What do you mean it is running slow? You are trying to toggle the pin every ms, are you looking at it with a scope? You are not going to see anything with your bare eyes.
Did you try PCM Programmer's program? It toggles the output every 1/2 a second.
mskala
PostPosted: Tue Jun 08, 2010 12:16 pm     Reply with quote
I agree you should run his program, but unless I read the data sheet
wrong you will need to change the clock=4000000 to clock=31000.
Fuse HS won't affect the internal oscillator.
And your initial statement that it is running 500 times too slow is a
clue. 8000000 / 500 = 16000, and I think you may have forgot your
toggle factor, so 16000 * 2 = 32KHz.
