ketron82
Graphic LCD WG12864A HELP |
Posted: Mon Jun 07, 2010 10:27 am |
Dear friends,
I am an italian student and in the past I have found more very good info in this forum!!
Now....I need your help.
I have bought a a GLCD WG12864A and I think that it working with a KS0108 controller.
This is the datasheet: http://doc.chipfind.ru/pdf/winstar/wg12864a.pdf
So....I have downloaded the GLCD.C library and I have changed the port in this way:
Code: | #ifndef GLCD_C
#define GLCD_C
#ifndef GLCD_WIDTH
#define GLCD_WIDTH 128 // Used for text wrapping by glcd_text57 function
#define ON 1
#define OFF 0
#define YES 1
#define NO 0
#ifndef GLCD_CS1
#define GLCD_CS1 PIN_D3 // Chip Selection 1
#ifndef GLCD_CS2
#define GLCD_CS2 PIN_D4 // Chip Selection 2
#ifndef GLCD_DI
#define GLCD_DI PIN_D0 // Data or Instruction input
#ifndef GLCD_RW
#define GLCD_RW PIN_D1 // Read/Write
#ifndef GLCD_E
#define GLCD_E PIN_D2 // Enable
#ifndef GLCD_RST
#define GLCD_RST PIN_D5 // Reset
void glcd_writeByte(char chip, BYTE data)
if(chip == GLCD_CS1) // Choose which chip to write to
output_high(GLCD_CS1);
output_high(GLCD_CS2);
output_low(GLCD_RW); // Set for writing
output_b(data); // Put the data on the port
output_high(GLCD_E); // Pulse the enable pin
delay_us(2);
output_low(GLCD_E);
output_low(GLCD_CS1); // Reset the chip select lines
output_low(GLCD_CS2);
// Purpose: Reads a byte of data from the specified chip
// Ouputs: A byte of data read from the chip
BYTE glcd_readByte(BYTE chip)
BYTE data; // Stores the data read from the LCD
if(chip == GLCD_CS1) // Choose which chip to read from
input_b(); // Set port d to input
output_high(GLCD_RW); // Set for reading
delay_us(2);
output_low(GLCD_E);
delay_us(2);
delay_us(2);
data = input_d(); // Get the data from the display's output register
output_low(GLCD_E);
return data; // Return the read data
and this is the MAIN function:
#include "C:\Documents and Settings\Administrator\Dati applicazioni\PICC\Projects\main.h"
#include "C:\Documents and Settings\Administrator\Dati applicazioni\PICC\Projects\glcd.c"
delay_us(1000);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
glcd_init (ON);
delay_us(1000);
glcd_fillScreen (0);
glcd_line(0, 0, 100, 60, 1);
I have simulated the compiled (main.hex) with PIC SIMULATOR IDE and it drawing correcly the line on GLCD.
I have controlled the pin of my PCB and all pin is right....but I can't see the line (or other pixel) on the GLCD....!
I have also connected Vee to GND with a potentiometer and the central pin of the potentiometer is connected to Vo (100k ohm).
Matching the potentiometer I can see the 128x64 pixel but i cannot see a line or other pixel on.
1) The RESET of the WG12864A is active with low voltage....is this the problem!!
2) Is the C code Right??
3) Is the library right for WG12864A GLCD??
4) The delay time is right??
5) How can i initialize my GLCD without library in simple mode for test??
6) PLEASE HELP ME ;)
Sorry for my very bad english and for the grammatical errors
Fabio Patriarca
IZ0CBG |
ketron82
Posted: Mon Jun 07, 2010 11:35 am |
Anyone that can help me?? |
balmer
Posted: Mon Jun 07, 2010 1:07 pm |
Your graphic LCD is of the backlight type, I guess.
Have you driven current betwen the backlight pins of the display ?
pin 19 Anode
pin 20 katode
Salutti |
Posted: Mon Jun 07, 2010 1:16 pm |
Quote: | 1) The RESET of the WG12864A is active with low voltage....is this the problem!!
The Reset pin is an output from the LCD. It shows the status of the
power-up internal initialization of the LCD. A low level indicates that
initialization is done, and the LCD is ready to accept commands. So
a low level is good. |
ketron82
Posted: Mon Jun 07, 2010 1:17 pm |
balmer wrote: | Your graphic LCD is of the backlight type, I guess.
pin 19 Anode
pin 20 katode
Salutti |
Many thanks for the reply....
I have connected the Anode and Katode correctly.....with a 100 ohm resistor and the LED is turned on.
Any idea??
Thanks...Fabio |
balmer
Posted: Mon Jun 07, 2010 2:26 pm |
The Reset pin is an input of the LCD.
You must set pin ...
output_high(GLCD_RST);
if not done, LCD will be set on reset status. |
ketron82
Posted: Mon Jun 07, 2010 2:44 pm |
Thanks PCM and BALMER....
the initialization of the glcd.c library that I downloaded is:
// Inputs: The initialization mode
// OFF - Turns the LCD off
// ON - Turns the LCD on
// Date: 5/28/2003
void glcd_init(int1 mode)
// Initialze some pins
output_low(GLCD_E);
output_low(GLCD_DI); // Set for instruction
glcd_writeByte(GLCD_CS1, 0xC0); // Specify first RAM line at the top
glcd_writeByte(GLCD_CS2, 0xC0); // of the screen
glcd_writeByte(GLCD_CS1, 0x40); // Set the column address to 0
glcd_writeByte(GLCD_CS2, 0x40);
glcd_writeByte(GLCD_CS1, 0xB8); // Set the page address to 0
glcd_writeByte(GLCD_CS2, 0xB8);
if(mode == ON)
glcd_writeByte(GLCD_CS1, 0x3F); // Turn the display on
glcd_writeByte(GLCD_CS2, 0x3F);
glcd_writeByte(GLCD_CS1, 0x3E); // Turn the display off
glcd_writeByte(GLCD_CS2, 0x3E);
glcd_fillScreen(OFF); // Clear the display
I think that the RST pin is set correctly yet.
no??
If the code is correct....the GLCD don't work again.
In the PIC SIMULATOR IDE Software....the GLCD draw a line but no circle and no text.
But I have one question....if the RST pin is an output of the LCD...I have to set it as an input for the PIC??
Many Thanks
Fabio |
ketron82
Posted: Mon Jun 07, 2010 6:18 pm |
I have found an error on my GLCD.C. Changing PORT I have understood to change this in the read function:
in
because I use PORT B as data.
So...I have tested hex in PIC Simulator IDE and NOW.....it draw circle etc.
The problem is that programming the 16f877a....my REAL GLCD won't work.
Nothing of nothing :(
Please....some one can help me??
Fabio |
