Setting configuration fuses manually on PIC24 [how-to]
Oli
PostPosted: Fri Feb 12, 2010 5:26 am     Reply with quote
Hi
I was not able to find this information on the forum, so I thought I would post it here. (from CCS support)
// First, you need to tell the compiler to stop using any default values like this:
#fuses NONE
// Then you use #rom to place the word at the right value:
#rom CW1={value}
#rom CW2={value}
#rom CW3={value}
//Use #define to give CW1, CW2 and CW3 the correct address.
Oli
update in PCD 4.099
PostPosted: Mon Jun 07, 2010 2:33 am     Reply with quote
The above doesn't work any more - I have been advised by CCS that this is now the correct way:
#fuses  1=0xFFFF
#fuses  2=0x207E
#fuses  3=0x3F7F
